Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
/createToken 404 error in basic example
Melisa_T_Intel
Hello..
I got the 404 error when I tried to consume /createToken...
In the code:
app.post('/createToken/', function(req, res) {
  var room = req.body.room || myRoom,
    username = req.body.username,
    role = req.body.role;
  N.API.createToken(room, username, role, function(token) {
    res.send(token);
  }, function(err) {
    res.send(err);
The N.API never returns the token...it always returns an error.
First I installed  the MCU server following the instruction for CentOS 7. I'm working with SSL certification and I copied the certificate into the ./cert folder and I run the initcert.js. Then I started the services and the example.
Any suggets?
Regards...
