Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
 for use 'CS_WebRTC_Client_SDK_Windows.v4.1', I have a trouble with call join room failed.
teddy_S
project linked sioclient.lib library and connect with the port 3001.
debug info:
(conferencesocketsignalingchannel.cc:90): Adding duplicated observer.
(conferencesocketsignalingchannel.cc:166): Socket.IO reconnecting.
(conferencesocketsignalingchannel.cc:156): Socket.IO connection failed.
Hr__Z
I faced same problem, just replace ip config in webrtc_agent/agent.toml:
network_interfaces = []  # default: []
TO:
network_interface = {name = "eth0",replaced_ip_address = "xx.xx.xx.xx"}
Hr__Z
And change ip_address = "" #default: "" in portal/portal.toml
teddy_S
TO:
thanks for your help, and I have to say that the configuration problem is difficult to check!
