Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
iOS build error ld: library not found for -lwoogeen
Cyrus_L_1
Innovator
Hi - I was trying to build the iOS sample p2psample
on building I got this error:: library not found for -lwoogeen
so, I made sure the library path went to the libs directory under CS_WebRTC_Client_SDK_iOS.v2.8
And I added both the libsioclient.a and libwoogeen.a  to the the "Build Phases".   cleaned the project and rebuilt - still the same error
Chunbo_H_Intel1
Have you added libwoogeen.a’s folder to “Library Search Paths” under “Build Settings”?
Cyrus_L_1
Innovator
Yup - that was the issue - example builds now thanks!
Chunbo_H_Intel1
Good. Glad to see it solved.
Thanks!
