Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
owt-server recording process
minipig19
hi everyone
   In the api documentation, the calling recording interface is /v1/rooms/{roomId}/recordings, but during the test (version v5), the v1 interface is unavailable.
when i use
curl -k -H "Accept: application/json" https://ip:3004/rooms/{roomid}/recordings -H "Content-type: application/json" -X POST -d@rec.json Request server recording , a Bad Request was returned.
The content of rec.json is as follows:
        "container": "mkv",
        "media":
            "video":"auto",
            "audio":"auto"
I can use the same method to create, query and delete rooms, but the recording interface has not been working. May I ask what steps and parameters are required for requesting server recording? Can you give me a suggestion.
minipig19
It has been solved, you need to query the streamid in the process
Add "from" "streamid" to "media"
start recording
