Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
2 technical questions
Brian_B_Intel2
An ISV of mine has two technical questions about SGX:
1. May I ask about typical range of enclaves ECALL / OCALL latencies? Some approximate estimate for the existing processors.
Of course some penalty exists - call in or from the enclave is not a direct function call.
But maybe your engineers have numerical information about this?
2. There is a trusted OpenSSL library in the SGX SDK for Windows - topenssl - in folder /IntelSGXSDK/src/X509Verifier/x509/topenssl .
But I found no such library in the Linux SDK. Does it exist only for Windows and there is no trusted OpenSSL project for the Linux?
Thank you!
Surenthar_S_Intel
Hi Brian,
#2. There is no trusted OpenSSL library for Linux. The below link confirms it .
https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/676097
-Surenthar.
Rohit_J_1
Hi Surenthar,
I have two technical questions about SGX:
1. Can we expect support for trusted OpenSSL project for the Linux from Intel?
2. Can SGX supports 256 bits key for encryption & decryption because as per developer reference guide by Intel SGX, key must be 128 bits?
Thank You,
- Rohit
Surenthar_S_Intel
              The topenssl library provided with the Windows samples is a one-off build intended for demonstration purposes. It is not a supported project.
            The AES encryption algorithms in the trusted crypto library provided with the Intel SGX SDK only support 128-bit keys. To use 256-bit keys developers would need to implement the algorithms themselves or port existing libraries to work inside an enclave.
-Surenthar
Juan_d_Intel
However, the Windows SDK 1.6 release exposes the underlying IPP crypto library. You may use the ippsAES_GCM API for symmetric encryption/decryption using 128, 192, or 256-bit key length.
