Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Allocating a buffer inside an Enclave
Meysam_t_
I am trying to allocate a buffer inside an enclave by using new in an ecall function as follows
This is what I have in Enclave.edl
public int buffer_allocator([out, size=len] char * buffer, size_t len);
And this is what I defined in Enclave.cpp
// to allocate a buffer in EPC
int buffer_allocator(char * buffer, size_t len)
    buffer = new char[len];
    if (!buffer)
        return (1);
    else
        return(0);
However, when I am running it, it returns 0 meaning that it fails to allocate memory. The question is how to allocate a buffer inside the enclave?
Scott_R_Intel
Hello.
That will allocate the buffer just fine, provided you have set up enough enclave heap size in the Enclave.config.xml for the length of buffer you're trying to allocate.
I think the problem is that you have your null check logic (or return values) backward, which is why you are getting a zero returned...  It should be "if (buffer) return 1;" or "if (!buffer) return 0;".
Regards.
Scott
