Hey,
I'm trying to call the PBC library in SGX Enclave to implement dynamic memory allocation of a 2D array of type element_t in PBC for use by later programs. Unfortunately, encountered some unknown program exits, so I am already struggling with creating the correct code.
I have configured my SGX 2.0 environment after following the instructions sgx_emm and tested the sgx_mm API successfully. the configuration file is as follows
<EnclaveConfiguration>
<ProdID>0</ProdID>
<ISVSVN>0</ISVSVN>
<TCSNum>3</TCSNum>
<TCSMinPool>1</TCSMinPool>
<TCSPolicy>1</TCSPolicy>
<TCSMaxNum>3</TCSMaxNum>
<StackMaxSize>0x1000000</StackMaxSize>
<StackMinSize>0x10000</StackMinSize>
<HeapMaxSize>0xF0000000</HeapMaxSize>
<HeapInitSize>0x9000</HeapInitSize>
<HeapMinSize>0x08000</HeapMinSize>
<UserRegionSize>0x90000000</UserRegionSize>
<DisableDebug>0</DisableDebug>
<MiscSelect>1</MiscSelect>
<MiscMask>0xFFFFFFFF</MiscMask>
</EnclaveConfiguration>
Now I need to call the PBC crypto library (already compiled lib_tpbc.a in /opt/intel/sgxsdk/lib64) in SGX Enclave to implement the dynamic memory allocation of a 2D array of type element_t, here is my function implementation.
//动态分配二维数组
void initialize_sets(int numSets, int sizeSet)
void *addr = 0;
//const size_t ALLOC_SIZE = 0x10000000; // 256M
size_t totalSize = numSets * sizeSet * sizeof(element_t);//1800B
const size_t alignedSize = calculate_aligned_size(totalSize);
int ret = sgx_mm_alloc(NULL, alignedSize, SGX_EMA_COMMIT_NOW, NULL, NULL, &addr);
printf("sgx_mm_alloc = %d\n", ret); //0
e_sets = (element_t **) (&addr);
for (int i = 0; i < numSets; i++)
*(e_sets + i) = (element_t *)(addr + i * sizeSet * sizeof(element_t));
for (int j = 0; j < sizeSet; j++)
element_init_Zr(e_sets[i][j], pairing);
element_random(e_sets[i][j]);
printf("initilize sets[%d][%d]\n", i, j);
Execute ./app and the result is as follows:
My problem is that even though I call sgx_mm_alloc to allocate large enough memory dynamically, it still can't initialize e_sets correctly, e.g., it can allocate 256M of memory successfully, but when numSets =8, sizeSet=15, alignedSize=4KB, the function can only initialize the array up to e_sets[7][6] and exits, and it doesn't report an error, so it's hard for me to locate the error.
Thanks for your help very much!
链接已复制
hi Iffa,
Thanks for your response.
Here's some of my hardware setup info.
root@ecsgx:~# lshw -short
H/W path Device Class Description
system Alibaba Cloud ECS
/0 bus Motherboard
/0/400 processor Intel(R) Xeon(R) Platinum 8369B CPU @ 2.70GHz
/0/1000 memory 4GiB System Memory
/0/1000/0 memory 4GiB DIMM RAM
/0/0 memory 96KiB BIOS
/0/100 bridge 440FX - 82441FX PMC [Natoma]
/0/100/1 bridge 82371SB PIIX3 ISA [Natoma/Triton II]
/0/100/1.3 bridge 82371AB/EB/MB PIIX4 ACPI
/0/100/2 display GD 5446
/0/100/3 communication Virtio console
/0/100/3/0 generic Virtual I/O device
/0/100/4 storage Virtio block device
/0/100/4/0 /dev/vda disk 42GB Virtual I/O device
/0/100/4/0/1 /dev/vda1 volume 1023KiB BIOS Boot partition
/0/100/4/0/2 /dev/vda2 volume 190MiB Windows FAT volume
/0/100/4/0/3 /dev/vda3 volume 39GiB EXT4 volume
/0/100/5 network Virtio network device
/0/100/5/0 eth0 network Ethernet interface
/0/100/6 generic Virtio memory balloon
/0/100/6/0 generic Virtual I/O device
/0/1 system PnP device PNP0b00
/0/2 input PnP device PNP0303
/0/3 input PnP device PNP0f13
/0/4 storage PnP device PNP0700
/0/5 communication PnP device PNP0501
root@ecsgx:~# free -m
总计 已用 空闲 共享 缓冲/缓存 可用
内存: 3746 2439 872 85 434 993
交换: 0 0 0
root@ecsgx:~# cat /proc/meminfo
MemTotal: 3836180 kB
MemFree: 888676 kB
MemAvailable: 1013912 kB
Buffers: 12172 kB
Cached: 391224 kB
SwapCached: 0 kB
Active: 184008 kB
Inactive: 2477356 kB
Active(anon): 4984 kB
Inactive(anon): 2349032 kB
Active(file): 179024 kB
Inactive(file): 128324 kB
Unevictable: 21336 kB
Mlocked: 18504 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 444 kB
Writeback: 0 kB
AnonPages: 2279308 kB
Mapped: 320328 kB
Shmem: 87864 kB
KReclaimable: 42720 kB
Slab: 121240 kB
SReclaimable: 42720 kB
SUnreclaim: 78520 kB
KernelStack: 15364 kB
PageTables: 35768 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1918088 kB
Committed_AS: 9041968 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 66472 kB
VmallocChunk: 0 kB
Percpu: 1824 kB
HardwareCorrupted: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 140568 kB
DirectMap2M: 2838528 kB
DirectMap1G: 1048576 kBI am looking forward to your reply, thanks again!
wendychao
We require you to create a debug enclave and use gdb to set breakpoints in the enclave and verify everything is as it should be stepping through.
This is the best way to find the source of your issue & debug it.
Cordially,
Iffa
