Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Error Intel SGX on Linux
João_R_
Hi. I'm trying to install mei for Linux: https://software.intel.com/en-us/file/37961-mei-712025zip
But when I try to make "make" I got:
: error: expected ‘,’ or ‘;’ before ‘__MODULE_STRING’
      __MODULE_STRING(AMT_WD_VALUE)
And also:
error: implicit declaration of function ‘mdelay’ [-Werror=implicit-function-declaration]
    mdelay(10); /* Wait for hardware disconnection ready */
I'm trying to install this because in the Intel-SGX: https://github.com/01org/linux-sgx , there are an example of SealedData that gives me the error:
Replay Protected DRM operation:
cannot get platform service capability, error code = 0x4001
Initialization the DRM failed.
Any help with this? Thank's in advance!
João_R_
I solved the problem, to acomplish that when I enabled MEI and install other required software (JHI, etc.) after PSW installed, then I needed to re-install PSW to trigger the initialization process.
Further information can be found in https://github.com/01org/linux-sgx/issues/93
Thanks for the help
Shivananda_H_Intel
Hi
Similar issue was handled earlier .Please check below link:
https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/614715
-Shivananda
João_R_
But how can I install MEI? It is giving me error with implicit declaration of function mdelay
I also tryed ME but also with erros.
João_R_
Also when I run the simulation mode I also get an error:
./app
Successfully initialized the DRM.
Successfully performed the DRM functions.
Successfully updated the DRM secret.
Successfully deleted the DRM secret.
	Replay Protected DRM update limitation:
cannot update_sealed_policy, function return fail, error code =0xf003
	Expected failure.
	The DRM secret update limitation reached.
	Replay Protected DRM replay attack protection:
Successfully updated the DRM functions.
cannot perform_sealed_policy, function return fail, error code =0xf002
	Expected failure.
	Replay attack to DRM functions is caught.
Successfully performed the DRM functions .
	Time based policy operation:
Successfully initialized the time based policy.
Successfully performed the time based policy functions.
	Time based policy expiration:
cannot perform_time_based_policy, function return fail, error code = 0xf006
	Expected failure.
	Time based policy has expired.
Enter a character before exit ...
gaston-hillar
Valued Contributor I
João R.,
Which specific Linux are you working with?
João_R_
Thanks for the help
gaston-hillar
Joao,
Thanks for sharing the solution to the problem. It is extremely useful to share the solution because others will benefit from reading the question and your own solution. :)
