Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Error code 16385 when creating an enclave
edigley_f_
When running the example in SampleCode/LocalAttestation as suggested in https://github.com/01org/linux-sgx I came across with the following error:
root@aca6aa8f028f:/tmp/LocalAttestation# ./app
Load Enclave Failure
Avaliable Enclaves
Enclave1 - EnclaveID 0
Enclave2 - EnclaveID 0
Enclave3 - EnclaveID 0Enclave1_test_create_session Ecall failed: Error code is 2002
Hit a key....
When inspecting the code in SampleCode/LocalAttestation/App/App.cpp, the following line is returning the code 16385 as error code.
sgx_create_enclave(ENCLAVE1_PATH, SGX_DEBUG_FLAG, &launch_token, &launch_token_updated, &e1_enclave_id, NULL );
What does this code mean? I've installed everything (sgx-drive/PSW/SDK) without problem.
PS: Is there any documentation where I can found all the error codes when dealing with SGX Application deployment?
Surenthar_S_Intel
Hi Edigley,
error 16385 is 0x4001 in hex, which corresponds to SGX_ERROR_SERVICE_UNAVAILABLE. This suggests that the platform services are not running on their Linux system. From the SDK documentation:
SGX_ERROR_SERVICE_UNAVAILABLE : sgx_create_enclave() needs the AE service to get a launch token. If the service is not available, the enclave may not be launched.
There is documentation for the Linux SDK here: https://01.org/intel-software-guard-extensions/documentation/intel-sgx-sdk-developer-reference
Thanks and Regards,
Surenthar Selvaraj
Francisco_C_Intel
The documentation is hosted on the 01.org page. On https://github.com/01org/linux-sgx , there is a "Documentation" section that contains a link to https://01.org/intel-softwareguard-extensions. On that site, you can find the developer reference ( https://01.org/sites/default/files/documentation/intel_sgx_sdk_developer_reference_for_linux_os_pdf.pdf ) under the "Documentation" tab.
Looking at the error codes, 0x4001, means "AE service did not respond or the requested service is not supported.".  I would check that the AE service is indeed running and the driver is loaded.
Surenthar_S_Intel
Hi Edigley,
Thanks and Regards,
Surenthar Selvaraj
George_M_1
I have the same error the run  in Simulation mode works well but in hardware mode i have the same error.
How you fixed that error?
