Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Examples loading enclave from buffer?
Daniel_ˢᵍˣ
Any examples available using sgx_create_enclave_from_buffer_ex and invoking ecalls and ocalls of the loaded enclave?
Sahira_Intel
While there are no samples using that function included in the SGX SDK, I am sending you a patch to convert SampleEnclave which uses sgx_create_enclave to sgx_create_enclave_from_buffer_ex (the file type is not supported so I am sending you a PM of it)
You can apply it to the linux-sgx repo.
Sincerely,
Sahira
Sahira_Intel
Sincerely,
Sahira
Daniel_ˢᵍˣ
Thank you Sahira, the patched example worked.
A related question:
In terms of security, is there an advantage in using mmap instead of reading the enclave into a buffer and using that buffer as input to sgx_create_enclave_from_buffer_ex?¹
¹ I created a hello world where the enclave is read into a buffer (fopen + fread) instead of using mmap and it appears to work as well.
Daniel_ˢᵍˣ
The patched sample worked, thank you.
A related question:
In terms of security, is there an advantage in using mmap instead of reading the enclave into a buffer (fopen + fread) and using that buffer in sgx_create_enclave_from_buffer_ex?
Sahira_Intel
It is technically faster. sgx_create_enclave_from_buffer_ex can be used without mmap if the user already has the enclave image buffer.
Sincerely,
Sahira
