Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Get SigRL via http request does not work
Buyukkardes__Sinan
Hi there,
It has been written that the result {gid} of sgx_get_extended_epid_group_id needs to be sent as a parameter according to API documentation. For me, the result is 0 on my platform.
I have the account and can verify that subscription key in the header is OK, (if I change a couple of bytes Http response becomes 401, which means it works fine)
https://api.trustedservices.intel.com/sgx/dev/attestation/v3/sigrl/00000000
But the thing is, when I perform a GET with the link above, the result is 404, do you think I needed to do something extra? Or the Signature Revocation Lists on IAS do not exist by default?
Btw, I am testing this subscription: "Product DEV Intel® Software Guard Extensions Attestation Service (Linkable)"
Best,
Sinan
JesusG_Intel
Hello Sinan,
It can get confusing because there are two EPID group IDs: 1) the extended Intel® EPID group ID, which is always zero, and 2) the Intel® EPID group ID (not extended). The one you want to use in the URL is the non-extended Intel® EPID group ID. You can get this {gid} by using the sgx_init_quote command. For details on sgx_init_qoute, refer to the Intel® Software Guard Extensions Developer Reference for your OS.
sgx_init_quote returns information needed by an Intel® SGX application to get a quote of one of its enclaves.
Syntax
sgx_status_t sgx_init_quote(
  sgx_target_info_t *p_target_info,
  sgx_epid_group_id_t *p_gid
Parameters
p_target_info [out]
Allows an enclave for which the quote is being created, to create report that
only QE can verify.
p_gid [out]
ID of platform’s current Intel® EPID group.
Is this helpful?
Jesus
Intel Customer Support
