Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
Got an error 0xe00d when trying to execute QuoteSamplecode in DCAP
heng__ruan
I'm trying to run QuoteSamplecode in DCAP from https://github.com/intel/SGXDataCenterAttestationPrimitives.
I referred to the procedure from https://github.com/bitsyizhan/sgx/blob/master/Intel_SGX_DCAP_Linux_SW_Installation_Guide.pdf.
I installed dcap driver and /dev/sgx appeared. But when executing samplecode, I got error:
This step is optional: the default enclave load policy is persistent:
set the enclave load policy as persistent:succeed!
[load_pce ../pce_wrapper.cpp:123] Error, call sgx_create_enclave for PCE fail [load_pce], SGXError:0001.
Step1: Call sgx_qe_get_target_info:Error in sgx_qe_get_target_info. 0xe00d
Source code said the 0xe00d means 'Unable to load the QE enclave'. I'm confused that whether I didn't install dcap driver correctly? But I didn't got error when I installed.
Thanks for your time!!!
Junli_S_Intel
What is your OS distribution? And what is your hardware type?
And Please check whether your driver has been installed successfully: check whether the node exist: /dev/sgx
heng__ruan
Thanks for your reply.
My OS distribution Information is
Linux test 4.15.0-66-generic #75-Ubuntu SMP Tue Oct 1 05:24:09 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux(gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1))
My hardware type informtion is:
Architecture:        x86_64
CPU op-mode(s):      32-bit, 64-bit
Byte Order:          Little Endian
CPU(s):              4
On-line CPU(s) list: 0-3
Thread(s) per core:  1
Core(s) per socket:  4
Socket(s):           1
NUMA node(s):        1
Vendor ID:           GenuineIntel
CPU family:          6
Model:               158
Model name:          Intel(R) Xeon(R) E-2174G CPU @ 3.80GHz
Stepping:            10
CPU MHz:             800.222
CPU max MHz:         4700.0000
CPU min MHz:         800.0000
BogoMIPS:            7584.00
Virtualization:      VT-x
L1d cache:           32K
L1i cache:           32K
L2 cache:            256K
L3 cache:            8192K
NUMA node0 CPU(s):   0-3
And the node: /dev/sgx exists.
I'm confused whether the appearance of node /dev/sgx  which means that I install the dcap driver correctly?
But why I can't run the dcap sample code successfully?
Junli_S_Intel
Sorry for my later response.  There are two potential reasons:
1. please check whether you have also installed another SGX driver: check whether there is another node /dev/isgx
2. And please check whether your hardware support Flex Launch Control feature.
贾__雨宁
I think I have the same problem:
de/QuoteGenerationSample$ ./app
[load_pce ../pce_wrapper.cpp:123] Error, call sgx_create_enclave for PCE fail [load_pce], SGXError:2006.
And the node: /dev/sgx dosen't exist.  Could you please tell me what should I do?
JesusG_Intel
Hello, you need to correctly install the Intel SGX DCAP driver in order to get /dev/sgx. Please follow the instructions from the installation guide in this directory: https://download.01.org/intel-sgx/latest/dcap-latest/linux/docs/. The binaries are separated by distribution here: https://download.01.org/intel-sgx/latest/dcap-latest/linux/distro/
Also, make sure your processor supports Flexible Launch Control (FLC). Intel® Xeon® E2200 series processors support FLC.
Jesus
