Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Help:A Simple_Enclave project Error
Shn_Y_
I tried to use Intel Pin to analyze a simple enclave project.The project is able to run in VS2013 ,simulation mode ,x64.(SDK1.6,PSW1.6)
But it appears a problem when i use Pin,as the following shows.
D:\tools\pin\source\tools\ManualExamples>pin -t obj-intel64\inscount0.dll -- obj-intel64\enclaveapp.exe
[sgx_create_enclavew ..\..\..\psw\urts\win\urts.cpp:83] Couldn't open file with CreateFile()
App: error 0x200f, failed to create enclave.
How could I solve this problem?
Surenthar_S_Intel
Did you run the application through command prompt or Local SGX Debugger?
If you are using the Local SGX Debugger, Please make sure change the "current working directory" pointing to $(OutDir) instead of $(ProjectDir) (Both App and Enclave)
Configuration Properties --> Debugging --> Working Directory --> $(OutDir).
Please look into below link for more information
-Surenthar
Shn_Y_
-Surenthar
hello
Thank you for your response.
I run the application through command prompt using intel pin.So how could I solve the problem...-_-
Surenthar_S_Intel
Please Change the "current working directory" pointing to $(OutDir) instead of $(ProjectDir) (Both App and Enclave)
-Surenthar
Shn_Y_
-Surenthar
Hello
Through Local sgx debugger ,I have changed  the "current working directory" pointing to $(OutDir) instead of $(ProjectDir) (Both App and Enclave) and it run without any problem.
But through command prompt using intel pin,the problem still exits.I wonder did anything go wrong there?
Francisco_C_Intel
You seem to be running:
So the "working directory" is "D:\tools\pin\source\tools\ManualExamples"
If your enclave is not located in the "working directory" you need to use absolute paths when calling create enclave or "cd" to the directory where the enclave is located and then run pin from there (using absolute path of the pin executable or adding its path to the PATH env var).
Shn_Y_
Hello
Actually my enclave was located in the "working directory" before.But I have used absolute paths when calling created enclave as you said.It runs without any problem.
Thank you.^_^
袁__子欣
Hello Mr shn Y,
     Recently my research will use pintools to do some instruments on SGX program, but always get into trouble with "cant open Enclave file". I notice that you have done some related work. Could you please tell how do you do your work with pintools? Thanks a lot.
Bruce Yuan
Francisco_C_Intel
In your code where you are creating enclaves, you should use the full path to the enclave file instead of only "enclave.signed.dll".
Francisco
