Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 讨论
How to run server/client wolfSSL Linux Enclave Example
Guy_M_
新手
3,048 次查看
I downloaded the wolfssl source folder from: https://github.com/wolfSSL/wolfssl.git.
I have built the libwolfssl.sgx.static.lib.a file with,
wolfssl debug, wolfssl benchmark and wolfcrypt enabled.
with the following command:
make -f sgx_t_static.mk CFLAGS=-DDEBUG_WOLFSSL HAVE_WOLFSSL_BENCHMARK=1 HAVE_WOLFSSL_TEST=1
I was following the example in this link: https://github.com/wolfSSL/wolfssl-examples/tree/master/SGX_Linux
and I'm stuck and the point where I'm supposed to run the server and the client with the
./App -s
and
./App -c
commands in the "/home/my_user/wolfssl"  directory.
it says "bash: ./App: No such file or directory".
how do I run the App file if it doesn't exist or maybe I should run a different file name?
0 项奖励
1 解答
Guy_M_
新手
3,048 次查看
I have managed to solve it by using this commands:
to run the server:
./examples/server/server
to run the client
./examples/client/client
在原帖中查看解决方案
0 项奖励
3 回复数
Guy_M_
新手
3,048 次查看
I solved it by running this command
~/wolfssl$ ./examples/server/server -p 11111
and then I opened another terminal to run the same thing for the server part.
0 项奖励
Guy_M_
新手
3,049 次查看
to run the server:
to run the client
0 项奖励
Jacob_B_2
新分销商 I
3,048 次查看
Hi Guy,
After building the wolfSSL library the example then needs to be built that links to the library. Changing directories to wolfssl-examples/SGX_Linux and following the README there. It has the application App be built with something like the following command
make SGX_MODE=HW SGX_PRERELEASE=1 SGX_WOLFSSL_LIB=~/wolfssl/IDE/LINUX-SGX/ WOLFSSL_ROOT=~/wolfssl SGX_DEBUG=0 HAVE_WOLFSSL_BENCHMARK=1 HAVE_WOLFSSL_TEST=1
The SGX server and client should then be ran with ./App -c or ./App -s from the wolfssl-examples/SGX_Linux directory. The examples ./examples/server/server and ./examples/client/client are non-SGX examples bundled with the wolfSSL library. It would be okay having one end of the connection be ./examples/server/server or ./examples/client/client for testing but if using only ./examples/server/server and ./examples/client/client then the example SGX code would not be running. Technical questions or support with building and using wolfSSL with SGX can be asked through [email protected].
Kind Regards,
Jacob
0 项奖励
回复
