Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Methods to check pointers when using [user_check] attribute?
jason_t_
In SGX developer guide Pointer Handling https://software.intel.com/en-us/node/696463, it mentions that
You may use the direction attribute to trade protection for performance. Otherwise, you must use the user_checkattribute described below and validate the data obtained from untrusted memory via pointers before using it, since the memory a pointer points to could change unexpectedly because it is stored in untrusted memory.
I get that a pointer from untrusted memory could potentially change without notification, but how is the code inside enclave supposed to check the pointer? It doesn't know what the value the pointer points to. It only knows the type of data. So is it just a type check?
Prabu_R_Intel
Hello Jason,
In certain situations, the restrictions imposed by the direction attribute may not support the application needs for data communication across the enclave boundary. For instance,  a buffer might be too large to fit in enclave memory and needs to be fragmented into smaller blocks that are then processed in a series of ECALLs, or an application might require  passing a pointer to trusted memory (enclave context) as en ECALL parameter.
 To support these specific scenarios, the EDL language provides the user_check attribute. Para-meters declared with the user_check attribute do not undergo any of the checks described  for [in] and [out] attributes. However, the ISV must understand the risks associated with passing pointers in and out the enclave, in general, and the user_check attribute, in  particular. The ISV must ensure that all the pointer checking and data copying is done correctly or risk compromising enclave secrets.
R.Prabu
jason_t_
Thank you R.Prabu, but I still have some issue in understanding it, especially the case when
In this case, the application code is responsible to fragment the buffer, right? So why not mark the ECALL with [in] attribute and simply call the ECALLs in a one-after-another fashion?
I guess my core question is what exactly should we check in the [user_check] pointers?
Thank you so much.
Jason
Juan_d_Intel
The documentation pertaining [user_check] is somewhat vague because the checks that need to be performed depend on the nature of the data being pointed at and how it will be used. At a minimum, for [user_check] you must confirm that the pointer isn't NULL and the location of the data pointed to. Whether it should be outside or inside enclave memory is application specific. Additional, application specific checks must follow.
