Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Missing Intel(R) SGX Debugger in Properties
Haarhoff__Thomas
I am having a problem with a setting up a new dev environment.
The \Intel\InteSGXSDK\src\SampleEnclave Solution is loaded into VS and can be compiled, but the Project Settings don't show the SGX Debugger, so I get the Error "Unable to start debugging. Check your debugger settings ..."
Project Settings General:
- Target Platform Version: 10.0.17763.0
- Platform Toolset: Visual Studio 15 (v140) [Tried VS 17 (v141) as well, same error]
Project Settings Debugging does not show the Intel SGX Debugger in the "Debugger to launch" Drop Down.
Versions i am using:
- Windows 10 Pro Version 1909 - OSBuild 18363.657
- Visual Studio 2017
- SGX SDK v2.6.100.2
SGX is enabled and the Device Manager shows:
- Intel(R) Software Guard Extensions Device
- Intel(R) Software Guard Extensions Software
Is there a version conflict im not aware of, or am I maybe missing some component?
Greetings
Thomas
JesusG_Intel
Hello Thomas,
Make sure your Platform Toolset under Properties -> General -> Platform ToolSet = Visual Studio 2017 (v141) or similar. The Intel SGX Debugger will then be available under Properties -> Debugging -> Debugger To Launch.
Make sure you do this for both Platforms, Win32 and x64, or the specific platform you are building for.
Also, make sure Visual Studio is installed before you install the SGX SDK.
If the above does not work for you, uninstall the SGX SDK via Windows Control Panel->Programs and Features, then reinstall it.
Use this article as your guide: https://software.intel.com/en-us/articles/getting-started-with-sgx-sdk-for-windows
Let us know if this solves your problem.
Jesus
Intel Customer Support
Haarhoff__Thomas
Hello Jesus,
As stated above, I used the v141 as Platform ToolSet, but the Debugger was not present in the Debugging drop-down.
However, reinstalling the SDK was a success and the Debugger is now present, and I can run the Program.
So yeah. Thanks for leading me into that direction.
Greetings
Thomas
