Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1560 Discussions
Need help! Undefined reference in trusted cpp enclave
zhou__boxiao
I am new to SGX linux development, and I am trying to build a TestEnclave.cpp)onto sgx.
I have encountered this undefined reference error when I linked the "trusted" part of the program.
make all
make -f sgx_u.mk LINUX_SGX_BUILD=0 all
make[1]: 进入目录“/home/zhou/下载/intel-sgx-ssl-master/Linux/sgx/test_pdp”
GEN  =>  app/TestEnclave_u.c
CC   <=  app/TestEnclave_u.c
LINK =>  TestApp
make[1]: 离开目录“/home/zhou/下载/intel-sgx-ssl-master/Linux/sgx/test_pdp”
----------- >> the untrusted part builds successfully
make -f sgx_t.mk LINUX_SGX_BUILD=0 all
GEN  =>  enclave/TestEnclave_t.c
CC   <=  enclave/TestEnclave_t.c
enclave/TestEnclave_t.o:在函数‘sgx_pdp_generate_proof_update’中:
TestEnclave_t.c:(.text+0x436):对‘pdp_generate_proof_update’未定义的引用 ----------------------- >> here
enclave/TestEnclave_t.o:在函数‘sgx_pdp_challenge’中:
sgx_t.mk:139: recipe for target 'TestEnclave.so' failed
TestEnclave_t.c:(.text+0x5f0):对‘pdp_challenge’未定义的引用 ----------------------- >> here
Makefile:34: recipe for target 'all' failed
TestEnclave_t.c:(.text+0x62a):对‘pdp_challenge’未定义的引用
enclave/TestEnclave_t.o:在函数‘sgx_pdp_tag_block’中:
TestEnclave_t.c:(.text+0x6d8):对‘pdp_tag_block’未定义的引用 ---------------------- >> here
TestEnclave_t.c:(.text+0x754):对‘pdp_tag_block’未定义的引用
TestEnclave_t.c:(.text+0x79e):对‘pdp_tag_block’未定义的引用
TestEnclave_t.c:(.text+0x7f9):对‘pdp_tag_block’未定义的引用
collect2: error: ld returned 1 exit status
make[1]: *** [TestEnclave.so] Error 1
make: *** [all] Error 2
17:53:59 Build Finished (took 815ms)
I have defined these functions(pdp_challenge,pdp_tag_block,etc) in the EDL file, and the untrusted part of TestEnclave.cpp linked successfully. But I don't know what's wrong with the trusted part.
Any help is greatly appreciated!!
my makefile is as follows:
TestEnclave_Cpp_Files := $(wildcard $(ENCLAVE_DIR)/*.cpp) $(wildcard $(ENCLAVE_DIR)/tests/*.cpp)
TestEnclave_C_Files := $(wildcard $(ENCLAVE_DIR)/*.c) $(wildcard $(ENCLAVE_DIR)/tests/*.c)
TestEnclave_Cpp_Objects := $(TestEnclave_Cpp_Files:.cpp=.o)
TestEnclave_C_Objects := $(TestEnclave_C_Files:.c=.o)
TestEnclave_Include_Paths := -I. -I$(ENCLAVE_DIR) -I$(SGX_SDK_INC) -I$(SGX_SDK_INC)/tlibc -I$(STL_PORT_INC)/stlport -I$(PACKAGE_INC) -IInclude
Common_C_Cpp_Flags := -DOS_ID=$(OS_ID) $(SGX_COMMON_CFLAGS)  -nostdinc -fvisibility=hidden -fpic -fpie -fstack-protector -fno-builtin-printf -Wformat -Wformat-security $(TestEnclave_Include_Paths) -include "tsgxsslio.h"
TestEnclave_C_Flags := $(Common_C_Cpp_Flags) -Wno-implicit-function-declaration -std=c11
TestEnclave_Cpp_Flags :=  $(Common_C_Cpp_Flags) -std=c++11 -nostdinc++
SgxSSL_Link_Libraries := -L$(OPENSSL_LIBRARY_PATH) -Wl,--whole-archive -l$(SGXSSL_Library_Name) -Wl,--no-whole-archive \
						 -l$(OpenSSL_Crypto_Library_Name)
Security_Link_Flags := -Wl,-z,noexecstack -Wl,-z,relro -Wl,-z,now -pie
TestEnclave_Link_Flags := $(SGX_COMMON_CFLAGS) -Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles \
	$(Security_Link_Flags) \
	$(SgxSSL_Link_Libraries) -L$(SGX_LIBRARY_PATH) \
	-Wl,--whole-archive -l$(Trts_Library_Name) -Wl,--no-whole-archive \
	-Wl,--start-group -lsgx_tstdc -lsgx_tstdcxx -lsgx_tcrypto $(TSETJMP_LIB) -l$(Service_Library_Name) -Wl,--end-group \
	-Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined \
	-Wl,-pie,-eenclave_entry -Wl,--export-dynamic  \
	-Wl,--defsym,__ImageBase=0 \
	-Wl,--version-script=$(ENCLAVE_DIR)/TestEnclave.lds
.PHONY: all test
all: TestEnclave.signed.so
# usually release mode don't sign the enclave, but here we want to run the test also in release mode
# this is not realy a release mode as the XML file don't disable debug - we can't load real release enclaves (white list)
test: all
######## TestEnclave Objects ########
。。。。(omitted)
TestEnclave.so: $(ENCLAVE_DIR)/TestEnclave_t.o $(TestEnclave_Cpp_Objects) $(TestEnclave_C_Objects)
	$(VCXX) $^ -o $@ $(TestEnclave_Link_Flags)
	@echo "LINK =>  $@"
TestEnclave.signed.so: TestEnclave.so
	@$(SGX_ENCLAVE_SIGNER) sign -key $(ENCLAVE_DIR)/TestEnclave_private.pem -enclave TestEnclave.so -out $@ -config $(ENCLAVE_DIR)/TestEnclave.config.xml
	@echo "SIGN =>  $@"
clean:
	@rm -f TestEnclave.* $(ENCLAVE_DIR)/TestEnclave_t.* $(TestEnclave_Cpp_Objects) $(TestEnclave_C_Objects)
my EDL file is as follows:
/* TestEnclave.edl - Top EDL file. */
enclave {
    include "user_types.h"
    from "sgx_tsgxssl.edl" import *;
     * uprint - invokes OCALL to display string buffer inside the enclave.
     *  [in]: copy the string buffer to App outside.
     *  [string]: specifies 'str' is a NULL terminated buffer.
    untrusted {
        void uprint([in, string] const char *str);
        void usgx_exit(int reason);
    trusted{
        public int pdp_verify_proof([in]PDP_key *key, [in]PDP_challenge *challenge, [in]PDP_proof *proof);
        public PDP_key *generate_pdp_key();
        public PDP_tag *pdp_tag_block([in]PDP_key *key,[in] unsigned char *block, size_t blocksize, size_t index);
        public PDP_challenge *pdp_challenge([in]PDP_key *key, size_t numfileblocks);
        public PDP_proof *pdp_generate_proof_update([in]PDP_key *key,[in] PDP_challenge *challenge,[in] PDP_tag *tag,[in,out]PDP_proof *proof, [in, size=blocksize]unsigned char *block, size_t blocksize, size_t j);
        public PDP_proof *pdp_generate_proof_final([in]PDP_key *key, [in]PDP_challenge *challenge, [in,out]PDP_proof *proof);
Thanks in advance!
zhou__boxiao
I have solved this problem!
Nappa__Antonio
Hello, I have had the same issue.
My Makefile had the following line
which is your line 5
the Makefile is trying to build the .so without having Enclave.o - I don't know why, it could be a problem with make version or the OS
before line 42 try to add
Enclave/Enclave.o: Enclave/Enclave.cpp
    $(CXX) $(Enclave_Cpp_Flags) -c $< -o $@
    @echo "CXX  <=  $<"
after 4 hours I solved the issue.
