Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
Please Help For compilation problem with SampleEnclave
Kelvin_C_
I have installed vs2015 update 3 with SDK 10 and Intel System studio
you_w_
New Contributor III
Hi:
Your error information is hard to see. Can you upload a clear  picture or give us your error information in text.
you
Francisco_C_Intel
If I read it correctly it says the floating point value does not fit in floating point type.
The supported compiler according to the release notes is
  Intel® Parallel Studio XE for Windows* Version 2016 Update 3
You can also try building the project using the Visual Studio 2015 compiler.
I am not familiar enough with Intel System Studio to understand why there is that mismatch in floating point size. I would check compiler options to see what the size each component thinks should be.
Kelvin_C_
Sorry belated reply.
The error message as following: @}WG19Q`5%QZ(AQ%W`BFHMK.png
Hoang_N_Intel
This is a well known issue and it is because the SampleEnclave's project setting is configured to use the Intel C++ Compiler by default. Please either install Intel C++ compiler or change the project setting to use Visual Studio C++ Compiler. Please see attachment for an example on how to change the setting.
Saeid_M_
I have created a YouTube video for creating and compiling SGX application on the VS2015 from scratch. I have used Intel Parallel Studio XE 2017 along with SGX SDK 1.7 in the Video. Attached is the source codes that  I have used in the video. I hope it helps.
https://www.youtube.com/watch?v=x3c62hsZbX0&t=26s
Kelvin_C_
Thanks Saeid , you are so helpful.
By the way, I have already deal with it by using vs compiler instead intel compiler.
Thanks all~
