Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Production Enclave Signing Query
Elephant
I have a question about the 2-step signing process for production enclaves.  Is the "gendata" option going to create a signing material that will have information about the CPU the enclave will be running on?  Will this CPU information be the basis of the signing platform/facility (i.e. Intel) on which private key to use when signing the signing material?
The reason for this question is that when we deploy a production software on different machines, do we need to create a signing material for each machine that we will deploy the enclave on?
Thanks a lot!
Kind Regards,
Elephant
Hoang_N_Intel
"gendata" does not involve the CPU information. According to page 15 in the developer guide at https://01.org/sites/default/files/documentation/intel_sgx_sdk_developer_reference_for_linux_os_pdf.pdf, it states that "the signature and buffer sections together with the header and body sections complete the enclave signature structure" for gendata.
The "2-step signing process" is intended to generate the MRSIGNER which involves only the Signing Identity key. So you should be able to deploy a production software on different machines. In fact, you should also be able to deploy multiple applications on different machines using the same signing key.
