Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Protected File System Library
yg1
I'm using Intel protected file system library. When I create a file using sgx_fopen_auto_key(), where is it exactly getting stored, and how can I locate it in the untrusted part?
Also, is it possible to get the path of the file?
JesusG_Intel
Hello Yg1,
The declaration of sgx_fopen_auto_key is:
sgx_fopen_auto_key
The sgx_fopen_auto_key function creates or opens a protected file.
Syntax
SGX_FILE* sgx_fopen_auto_key(
const char* filename,
const char* mode
Parameters
filename [in]
The name of the file to be created or opened.
You specify the file path, which is where the file is located, in the first argument, const char* filename. The API for sgx_fopen behaves like its counterpart in C, fopen.
The protected file cannot be opened for reading or writing by the untrusted application since the file is encrypted with an enclave sealing key. The section Intel® Protected File System Library in the SGX Developer Reference Guide has more details.
Related Information:
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Yg1,
sgx_fopen_auto_key
Syntax
const char* mode
Parameters
filename [in]
Sincerely,
Jesus G.
yg1
Hello Jesus,
Thanks for your information, but should I need to take backup of the file created by sgx_fopen_auto_key function, so where can I find the file content?​
JesusG_Intel
Hello Yg1,
You specify the location of the file in the filepath argument: const char* filename.
If you don't specify a full path, the file will be created in the same directory where your app is executed.
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
