Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX Eclipse plugin
Sam5
Hi
The eclipse plugin provided with SGX SDK for Linux* OS, only installs SGX user guide and there are no SGX tools available with plugin. How do I get that?
Thank You
Surenthar_S_Intel
Hi Sam,
The eclipse plugin build from commandline requires the following variables to be set
$ECLIPSE_HOME - Path to eclipse home. In order to build the plugin eclipse needs to be installed.
$RELEASE_ID - The release id for the plugin.
The plugin has been tested with the following Eclipse ADT version
Build: v22.3.0-887826
The following plugins are pre-requisites to be installed in Eclipse before trying to build the plugin.
1. Eclipse IDE for C/C++ Developers  4.5.1.20150917-1200 (tested_version)
2. Eclipse PDE Plug-in Developer Resources   3.11.1.v20150904-0345 (tested_version)
If the sgx eclipse plugin is already installed to eclipse and to build and install a newer version, uninstall the old version and start eclipse with the -clean option.
Then try to build the new version of the plugin and install it in eclipse.
http://wiki.eclipse.org/FAQ_How_do_I_remove_a_plug-in%3F
Once the build script is run, the folder build_directory/updatesite/sgx-eclipse-plugin contains the update site. This is the path that needs to be provided to the eclipse while doing installation.
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Sam,
Thanks and Regards,
Surenthar Selvaraj
Sam5
Thanks for your detailed information
Savvas_S_
What should $RELEASE_ID be set to?
Thanks!
Surenthar_S_Intel
$RELEASE_ID - The release id for the plugin. The release id should be changed for each source codes updates.
-Surenthar
