Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Sample Project in Linux SDK
SAM_R_2
I currently have Eclipse Mars installed on an Ubuntu 14.04.5 LTS VM. I've also installed the SGX Eclipse plugin manually by adding it as an archive.
I've checked out the SDK, and built some of the example projects on the command line successfully. I tried importing the SampleEnclave (from the SDK) project, there are multiple "could not be resolved" errors. Any help or direction would be appreciated.
Thanks!
Surenthar_S_Intel
Hi Sam,
Already eclipse projects set up are avilabe in Linux SDK examples and you need to import them in to your project. It will resolve all your errors
-Surenthar
Surenthar_S_Intel
Hi Sam,
-Surenthar
SAM_R_2
Thanks Surenthar...
