I would like to clarify the sample_libcrypto.h header in the sample code for Remote Attestation. Are the API's in that library working exactly the same as the ones in sgx_tcrypto library, e,g. sample_rijndael128GCM_encrypt the same as sgx_rijndael128GCM_encrypt? The endianness of the API's are expected the same? The point is, can I put the functions that use sample_libcrypto.h inside an enclave and change the references to sample_XXX APIs to sgx_XXX? Would there be issues in that?
Thanks a lot!
Kind Regards,
Elephant
連結已複製
Please do NOT use the sample lib crypto in production code. Please see:
https://github.com/01org/linux-sgx/blob/master/sdk/sample_libcrypto/sample_libcrypto.cpp
And "find" __do_get_rand32 before deciding whether this is a suitable library for production.
Hi Francisco,
Thanks for taking time to answer my question. I know that sample lib crypto is not meant for production, that's why I was asking if I can do all the work inside an enclave and use the SGX crypto API's instead of using the sample lib crypto. I wanted to know if sample_xxxx_xxxx API's map directly with sgx_xxxx_xxxx API's.
Thanks a lot!
Kind Regards,
Elephant
