Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Sgx_seal_data_ex example code
glenn_t_
I would like to seal data to the enclave identity rather than the signer identity. I gather this has to be done using sgx_seal_data_ex but I am having trouble finding example code to use this. Does example code exist? Thanks
Shivananda_H_Intel
You can refer to the below file for the usage of sgx_seal_data_ex.
https://github.com/01org/linux-sgx/blob/master/sdk/tseal/tSeal.cpp
SGX_KEYPOLICY_MRSIGNER and SGX_KEYPOLICY_MRENCLAVE are defined in sgx_key.h
Shivananda
Anusha_K_Intel
The syntax for the function is as follows
sgx_status_t sgx_seal_data_ex(
const uint16_t key_policy,
const sgx_attributes_t attribute_mask,
const sgx_misc_select_t misc_mask,
const uint32_t additional_MACtext_length,
const uint8_t * p_additional_MACtext,
const uint32_t text2encrypt_length,
const uint8_t * p_text2encrypt,
const uint32_t sealed_data_size,
sgx_sealed_data_t * p_sealed_data
In the sample code of sealed Data application we can see the usage of sgx_seal_data() function but sgx_seal_data_ex() is not used.You can see that code for reference.
The value of key_policy should be given as to 0x0001 to use the enclave's measurement register.
You need to add sgx_tseal.h as your header file and sgx_tservice.lib as your library.
More information regarding the function is given here: https://software.intel.com/en-us/node/709129
glenn_t_
So I define my function and internally define parameters  for the sgx_seal_data_ex.  The parameters i defined in my function seem to be lost. So if i have to pass all the arguments for seal_data_ex into my function its not clear how this should be defined in the .edl file. The documentation for .edl files does not say what the convention is for square brackets [].
Anusha_K_Intel
What is the issue you are facing while giving the square brackets as input in the edl file??
