Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
Signing Enclave with RSA Keys in two step process
bergmann__Tina
Dear All,
I want to break down the build process of the SGX and therefore I am trying to sign the Enclave myself using the two step process. Once the Enclave is compiled as an enclave.so, I perform the following steps manually to get the signed Enclave:
Generating Keypair:
openssl genrsa -out my_private_key.pem -3 3072
openssl rsa -in my_private_key.pem -pubout -out my_public_key.pem
Siging the Enclave:
2-Step Process:
sgx_sign gendata -enclave enclave.so -config Enclave/Enclave.config.xml -out enclave_hash.hex
openssl dgst -sha256  -out signature.hex  -sign my_private_key.pem -keyform PEM  enclave_hash.hex
sgx_sign catsig -enclave enclave.so -config Enclave/Enclave.config.xml -out enclave_signed.so -key my_public_key.pem -sig signature.hex -unsigned enclave_hash.hex
All except the last step throws up the following error:
"Error happened while signing the Enclave."
Can someone point out the problem?
Hoang_N_Intel
It looks like that when you generate the key, you did not specify the encryption algorithm.
It should be   $ openssl genrsa -aes128 -out my_private_key.pem -3 3072
instead of just $ openssl genrsa  -out my_private_key.pem -3 3072
Yan_M_1
Is it possible to sign enclave with and RSA key with an exponent other than 3?
Hoang_N_Intel
No, please do not use an exponent value other than 3. It must be 3 as the SGX AESM uses that value along with the public key to validate and load the Enclave.
