Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Software controlled SGX
Grigory_M_
The BIOS of the motherboard (Asus z170 BIOS 3101) supports software controlled SGX. so, to use the SGX, it should be first activated by the software. I would expect that PSW installer should activate it, however, it does not have that functionality. It also does not export sgx_cap_enable_device/sgx_enable_device functions.
What should be the procedure to activate the SGX in this case? Are there any utilities/UEFI roms to activate it?
AArya2
What's Software Controlled SGX?
(Sorry if the notification gave you the impression that this would be an answer :p)
Francisco_C_Intel
sgx_enable_device is exposed in sgx_uae_service.dll
The SampleEnclave, for example, calls this API. The idea is that the PSW can be installed on systems where SGX isn't yet enabled. End-user applications that will actually use SGX functionality can enable it during their installation (sgx_cap_enable_device), or at runtime (sgx_enable_device).
Note that a restart is required afterwards.
Grigory_M_
Thanks, Francisco!
I was referring to the Linux SGX SDK. Is there any specification of what sgx_enable_device implementation in Windows SGX SDK does, so I could implement that functionality by myself, if no tool exists?
Francisco_C_Intel
I don't believe so. Can you go to the BIOS and set SGX to ENABLED manually?
Grigory_M_
The BIOS only contains "software-controlled" SGX, no "Enabled" option.
Rodolfo_S_
New Contributor III
Hi, Grigory.
I believe this is still not available on the Linux SDK. What you could do is install a virtual machine with Windows and enable it from there.
Kobi_G_
Facing the same issue. Have Z170-A, confirmed that SGX exists on the CPU using CPUID, have only "software controlled" option for SGX in the bios. Is "sgx_enable_device" possible to call from Linux yet? Will a VM method even work?
Francisco_C_Intel
Please see
https://github.com/01org/linux-sgx/pull/107
I don't think it's been merged yet, but you should be able to use that to unblock your progress.
Francisco
