Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
What does the error code 0x4004 mean?
Shi__Wenjie
I tried to build the SampleEnclave provided by SGX SDK for linux in release mode, but the enclave didn't work.
To build it in release mode, (1) I set the option <DisableDebug> in Enclave.config.xml to 0,  (2) passed 0 as the 2nd parameter of API sgx_create_enclave instead of the macro SGX_DEBUG_FLAG, and (3) finally, when the build finished, I signed the enclave with the file Enclave/Enclave_private.pem.
When I run the app, the enclave returned the error code 0x4004. As mentioned in  the "Intel SGX SDK Developer Reference", 0x4004 means "Enclave has no privilege to get a launch token.". I can't understand it very well,  the problem seems happened when the app trying to load the enclave, but I don't know why.
I want to know the reason why the error code 0x4004 is returned and how to fix it?
Thanks a lot!
Junli_S_Intel
the problem is located:  (2) passed 0 as the 2nd parameter of API sgx_create_enclave instead of the macro SGX_DEBUG_FLAG
When you tried to load your enclave, your enclave's signing key should in Lanuch Enclave's white-list.  Based on your description, your are using your owner signing key,  So the create enclave operation would fail.
To let the APP work, please passed 1 as the 2nd parameter of API sgx_create_enclave.
