Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
install PSW error
xiaowen__ouyang
When I run the latest Intel(R)_SGX_Windows_x64_PSW_1.9.105.42143.exe, the installer shows “Operating system 'Windows 10 Home 10.0.16299' is not supported”. But my windows version is 1709. What should I do?
Francisco_C_Intel
Hi.
For reference purposes, https://support.microsoft.com/en-us/help/4043454 contains the builds of the OS that correspond to specific versions.
Build 10.0.16299 is "the same" as version 1709, formally known as "Fall Creators Update".
If SGX is enabled and Windows Update is configured to receive updates, the OS will automatically download our software, which will appear in Device Manager -> Software Components instead of the Control Panel -> Add/Remove Programs.
If you downloaded the software package from the registration center, there are more details in the "Intel SGX Installation Guide for Windows OS".
Please let us know if you still are having problems.
Francisco
Francisco_C_Intel
Hi.
Francisco
xiaowen__ouyang
Thank you very much!
I have checked my win10 is up to date, so according to your prompts, I found it.
bashar__golam1
How I know that PSW is correctly installed in my system.
From BIOS I configured it Enable and whenever I run Intel(R)_SGX_Windows_x64_PSW_2.3.100.49777.exe , it gives the error
This software (or one of its components) was already installed on this platform by the .inf installer. Install will cancel.
The installed version of Windows is not supported by this installer. If you enable Intel® SGX on your system, Windows Update install Intel® SGX Platform Software automatically.
Francisco_C_Intel
Based on the message "This software (or one of its components) was already installed on this platform by the .inf installer. Install will cancel." the software is already installed.
You can check the version and other details by going to
Device Manager -> Software Components -> Intel(R) Software Guard Extensions Software
