I am an Intel employee and want to apply for an account with FPGA hardware access. While the only register website is for external users.
While I still used this link and registered an account. After it, I want to access Devcloud under Intel firewall, so I use this guide: https://github.com/intel/FPGA-Devcloud/blob/master/main/Devcloud_Access_Instructions/README.md#connection-methods and set the .ssh/config.
Then I run `ssh colfax-intel` in Mobaxterm, it shows the error log.
stty: standard input: Inappropriate ioctl for device
Permission denied (publickey).
ssh_exchange_identification: Connection closed by remote host
Any suggestions on this issue? Thanks.
And another question, is Oneapi 23.1 version with Quartus for FPGA supported on Devcloud now?
He
Thank you for posting in Intel communities. The document which you're following is an outdated one and the procedure has changed. Now, we could access FPGA hardware from oneAPI DevCloud by changing the queue to FPGA queue.
Firstly, you would need to connect to DevCloud via SSH. You could follow the below steps:
- Follow the Manual Configuration from this: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
- If you’re behind Proxy(using Intel network), Please add the below content in your config file:
Host devcloud.proxy
User <user>
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-<user>.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
Hostname ssh.devcloud.intel.com
LocalForward 4022 c009:22
ProxyCommand nc -x <proxy_name>:<port> %h %p
- As you’re an Intel employee, make sure you’re using the right proxy as per your location.
- You could open your Mobaxterm and run the below command to connect to devcloud via Intel Proxy.
ssh devcloud.proxy
- Once you login to OneAPI DevCloud via SSH, you could get into FPGA queue with the below commands:
source /data/intel_fpga/devcloudLoginToolSetup.sh
devcloud_login
You would be logged into a compute node with FPGA hardware(Arria10/Stratix10)
- To make use of Quartus for FPGA, you would have to setup the tools with below commands
tools_setup
From above screenshot, you can see that there are several versions of Quartus Prime available.
If this resolves your issue, make sure to accept this as a solution. This helps others with similar issue. Thank you!
Alekhya
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
Hi Alekhya,
Thank you for the solution. While I still cound not access the DevCloud through ssh command.
My ssh config setting is as below. Seems no fault of it.
Host devcloud.proxy
User u191868
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-191868.txt
User guest
ProxyCommand nc -x proxy-prc.intel.com:913 %h %p
Now I still get the error log like this.
Thank you so much for supporting.
He
Hi @He4Forum ,
We are sorry to hear that. Which configuration did you try to connect to DevCloud? Manual or automatic configuration?
And please make the below modifications to your config file and please check if the issue still persists.
User guest
ProxyCommand nc -x proxy-prc.intel.com %h %p
If this resolved your issue, make sure to accept this as solution. This helps others with similar issue! Thank you!
Alekhya
We have not heard back from you. Could you please give us an update regarding this issue?
Alekhya
Hi Alekhya,
Sorry for replying late. I still cannot access the server after modification.
He
Could you please try connecting to devcloud without proxy? Does it work? Could you please check and let us know?
If yes, you have to give the right proxy command in your config file to connect to devcloud behind proxy.
Alekhya
Alekhya
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel
Alekhya
