Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Aria 10 OpenCL nodes error (Error enumerating AFCs: no driver available)
batmanbatak
Hi
It seems like Aria 10 Open CL nodes have errors:
1. When I select nodes for arria 10 openCL there are errors that was never there before:
-bash: /usr/bin/tclsh: No such file or directory
-bash: export: _moduleraw: not a function
-bash: export: module: not a function
2. Those errors causing several problems:
cannot write aocx bitstream to FPGA
Error parsing device name '▒▒▒▒'
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
Error programming device
aocl program: Program failed.
and this error only exist in Aria 10 openCL nodes,
in Aria 10 oneAPI nodes, Stratix 10 nodes everything is fine
JyothisV_Intel
Good day to you.
Sorry for the inconvenience caused. We were able to find some issues with the Arria 10 OpenCL nodes as observed by you. We are working with the development team to get this resolved. Thanks for reporting the same and we will let you know when it is fixed.
Jyothis V James
batmanbatak
Hi any update when it will be fixed?
JyothisV_Intel
Good day to you.
Apologies for the delay in getting back to you.
The issues with the AFC drivers in all Arria 10 OpenCL FPGA cards has been resolved. Kindly verify from your side.
If this resolves your issues, kindly mark this as a solution as it might help others who are facing a similar issue.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
We have not received an update from you. Do get back to us if you are still facing the reported issue on Arria 10 OpenCL nodes.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
We have not received any response from you yet. Intel will no longer monitor this thread and all interactions will be consider community only.
If you need assistance while using any Intel products or services, please post a new question.
Thanks and Regards,
Jyothis V James
