Hello!
I am using this guide: https://devcloud.intel.com/oneapi/get_started/renderingToolkitSamples/
1.4 Setup Remote Desktop I have a problem when I open TurboVNC and type in vncserver: localhost:1 and click connect then a error pops up with text: Connection closed, Attempt to reconnect?
My username is: Desktop 'TurboVNC: s001-n146:1 (u212310)' started on display s001-n146:1
Thank you for posting in Intel communities.
I hope you are doing well.
We are facing the same from our end, but I have some work to do. Please follow the below steps (make sure you are not using proxy).
1) In the first terminal,
ssh devcloud
qsub -I -l nodes=1:renderkit:ppn=2
/opt/TurboVNC/bin/vncserver -otp
After running the above command the output looks like below.
Note:
started on display s001-n152:<display number>
now you need to use that display number as shown below
port= 5900+<display number>
in my case, it is 5906
You will be connected to a compute node(let's assume you have connected to the s001-n152 node) and A one-time OTP will be generated.
2) In the second terminal
assuming port number as 5906:
ssh -L 5906:localhost:5906 devcloud
after login to the compute node please enter the below command:
ssh -L 5906:localhost:5906 <compute node>
example: ssh -L 5906:localhost:5906 s001-n152
Attaching screenshots for your reference.
After you are connected to the compute node is the second terminal too, Open turbo VNC viewer and enter
localhost:5906 (<here keep your portnumber>) and click on connect and enter one-time password
Note:
If you get an authentication failed error.
Please run the below command inside 1st terminal
/opt/TurboVNC/bin/vncpasswd -o -display :<display_number>
example: /opt/TurboVNC/bin/vncpasswd -o -display :6
After running the above command inside 1st terminal you are going to get a new one-time password
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
Hello sir I tried the same things as mentioned by you above but still I am getting the same errors. I have attached the images regarding the issues about please look into them and a reply will be highly appreciated.
Thank you.
