Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1527 Discussions
Error while trying pass the public intel model to model optimizer in intel devcloud
Tchouanga__Franck
(base) u38804@s001-n053:~/public/faster_rcnn_inception_v2_coco$ ls
faster_rcnn_inception_v2_coco_2018_01_28
(base) u38804@s001-n053:~/public/faster_rcnn_inception_v2_coco$ cd faster_rcnn_inception_v2_coco_2018_01_28
(base) u38804@s001-n053:~/public/faster_rcnn_inception_v2_coco/faster_rcnn_inception_v2_coco_2018_01_28$ ls
checkpoint  frozen_inference_graph.pb  model.ckpt.data-00000-of-00001  model.ckpt.index  model.ckpt.meta  pipeline.config  saved_model
(base) u38804@s001-n053:~/public/faster_rcnn_inception_v2_coco/faster_rcnn_inception_v2_coco_2018_01_28$ python /opt/intel/openvino/deployment_tools/model_optimizer/mo.py --input_model frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config pipeline.config --reverse_input_channels --tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json
Traceback (most recent call last):
  File "/opt/intel/openvino/deployment_tools/model_optimizer/mo.py", line 28, in <module>
    from mo.main import main
  File "/glob/development-tools/versions/oneapi/beta06/openvino_2020.2.120/deployment_tools/model_optimizer/mo/main.py", line 26, in <module>
    from mo.pipeline.unified import unified_pipeline
  File "/glob/development-tools/versions/oneapi/beta06/openvino_2020.2.120/deployment_tools/model_optimizer/mo/pipeline/unified.py", line 19, in <module>
    from mo.pipeline.common import get_ir_version
  File "/glob/development-tools/versions/oneapi/beta06/openvino_2020.2.120/deployment_tools/model_optimizer/mo/pipeline/common.py", line 27, in <module>
    from mo.back.ie_ir_ver_2.emitter import port_renumber, serialize_constants, generate_ie_ir, serialize_mean_image
  File "/glob/development-tools/versions/oneapi/beta06/openvino_2020.2.120/deployment_tools/model_optimizer/mo/back/ie_ir_ver_2/emitter.py", line 18, in <module>
    from defusedxml.minidom import parseString
ModuleNotFoundError: No module named 'defusedxml'
please help
Eltablawy__Alaa
Hi Franck,
Thanks for reaching out. I believe your question does not belong to this forum. This forum is for Intel® Devcloud for Edge questions, and the error message you posted shows that you are running your job on Intel® DevCloud. Please try posting your question in the forum for Intel® DevCloud.
Alaa
Tchouanga__Franck
The form has become outdated. Copy any unsaved work in the form below and then reload this page.
please I am getting that error when I post a question in intel devcloud forum please can you help to solve that even after reloading it still does not work
Tchouanga__Franck
that is why I posted it here
Gael_H_Intel
Franck, I moved your question to the DevCloud Forum. Please check this link:  https://software.intel.com/en-us/forums/intel-devcloud
AthiraM_Intel
Did you source the openvino environment before running the script, if not please source using the below command
source /opt/intel/openvino/bin/setupvars.sh
If you are facing the same issue after sourcing, please try to pip install the missing module
For example:
pip install defusedxml
Hope this helps. If you face any further issue please let us know
Tchouanga__Franck
thanks it worked fine
AthiraM_Intel
Thanks for the confirmation. We are closing this case, please feel free to raise a new thread in case of further issues.
