I generated the key as per instructions and uploaded its image and generated file in the key contents section but got the following error:
could not decode sshpublickey: illegal base64 data at input byte 4
Please suggest how to fix this and continue.
I also tried uploading some AI based packages using sudo command but it showed message permission denied, how to obtain the permission to do so? I tried adding a user but got the error message:
useradd: Permission denied.
useradd: cannot lock /etc/passwd; try again later.
echo '%sudo ALL=(ALL) NOPASSWD:ALL' >> /etc/sudoers
bash: /etc/sudoers: Permission denied
Hi Sid5,
Could you provide us a screenshot of the error message that you are facing for further investigation? At the same time, please provide us with the Intel® Developer Cloud Instance Details as below:
Instance ID/Resource ID:
Instance Type:
Cloud Account ID:
For your information, the Batch Service instance does not provide the user with sudo privileges. Hope this helps.
Luwe
Hi Sid5,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Luwe
Hi Luwe,
I apologize for the late reply, I have generated the key now but still having issues with the sudo permissions. It asks for a password that I cannot find, its not the same as the login password. Here's the SS:
Thanks & regards
Siddhartha Sharma
![](/skins/images/318B71AC6E18CAB8E2CA944B2397E849/responsive_peak/images/icon_anonymous_message.png)
