Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Conda Installation raises AssertionErrors (MatchSpec)
Paul_M_3
I have tried following instructions provided in the documentation (https://software.intel.com/sites/default/files/managed/9d/09/Conda-Guide-for-Intel(R)-Distribution-for-Python-2017.pdf), however, after creating a new conda environment and activating it
conda config --add channels intel
conda create -n intelpython python=3
activate intelpython
trying to install intelpython3_core raises assertion errors (it does not seem to be package-related, since the packages mentioned change from run to run):
conda install intelpython3_core
AssertionError: pytz-2015.4-intel_py2.7_1.tar.bz2 MatchSpec('nose 1.3.7 intel_py
2.7_1')
Some infos on the conda-installation:
platform : win-64
conda version : 3.7.0
conda-build version : 1.8.2
python version : 3.4.1.final.0
requests version : 2.4.1
Is there a way to fix/work around this problem? Thanks!
Robert_C_Intel
I tried python2 & 3 and it is working for me. Can you try updating your conda? This is what I have.
             platform : win-64
        conda version : 4.0.6
  conda-build version : 1.11.0
       python version : 2.7.11.final.0
     requests version : 2.9.1
Robert_C_Intel
             platform : win-64
Paul_M_3
Hi Robert,
Thanks, updating conda seems to have solved the issue, with 4.0.6 it also worked for me. Could you tell me whether it is at all possible to profile python code without elevated user rights on windows?
Paul
Vasilij_L_Intel
Hi Paul,
We've recently released Python profiling support in Intel® VTune™ Amplifier 2017 Beta, see https://software.intel.com/en-us/python-profiling
It would obviously require elevated rights to install the software, but afterwards you will be able to profile your Python code without administrative rights using Basic Hotspots analysis. Please check documentation available after installation for more (unfortunately online documentation is available for 2016 release only, 2017 is in Beta status now).
Vasilij
Kuila__Debdas
Dear Intel,
I have installed the "Intel Distribution for Python" and tried to run Python but am not able to succeed as it keeps throwing errors as "conda environment is not active". So, I followed the instruction and have checked at "https://conda.io/projects/conda/en/latest/user-guide/tasks/manage-environments.html#activating-an-environment" but not able to solve the problem.
Please help.
