Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Configure number of processors available to MKL NumPy
Gilbert_F_
Is there a config file or a command line parameter to set the number of available processors for MKLnumpy to take advantage of?
Anton_M_Intel
Welcome to the forum and thank you for the question!
MKL uses the best number of threads by default, e.g. (on Windows):
> python -c "import ctypes; mkl_rt = ctypes.CDLL('mkl_rt.dll'); print mkl_rt.mkl_get_max_threads()"
16
If you want to change it, set MKL_NUM_THREADS environment variable to specify the number of threads to run in parallel, e.g.:
> set MKL_NUM_THREADS=1
1
Please see this blog for more information regarding recommended environment variable settings for multithreading MKL. Or refer to MKL threading control API here.
RL5
16
How does one check the number of threads in linux?
Robert_C_Intel
For linux, you need to change the name of the shared library:
python -c "import ctypes; mkl_rt = ctypes.CDLL('libmkl_rt.so'); print(mkl_rt.mkl_get_max_threads())"
RL5
Thanks Robert, I was missing the 'lib' part of the name.
Zhanwen_C_
For future reference, on a Mac you simply change "mkl_rt.dll"/"libmkl_rt.so" to "libmkl_rt.dylib", like so:
```python
python -c "import ctypes; mkl_rt = ctypes.CDLL('libmkl_rt.dylib'); print(mkl_rt.mkl_get_max_threads())"
