Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Debugging Symbols
Modi__Lionel
Hi, where can I find the debugging symbols (i.e. python36.pdb) for mixed c++ code debugging??
Thanks!
Oleksandr_P_Intel
python36.pdb is not currently being a part of Intel(R) Distribution for Python* on Windows.
As a work-around you can install python from Anaconda, which does come with python36.pdb
To do that, perform the following steps
1. Clone your current IDP environment, assuming it has name intel.
conda create -n pydbg --clone intel
2. Activate it using
activate pydbg
3. To install Anaconda's python into it, you would need to uninstall meta-packages firtst:
conda remove inputpython3_core
conda install -c https://repo.continuum.io/pkgs/main/win-64 python=3.6
4. Confirm that you have %CONDA_PREFIX%/python36.pdb
Try debugging your application in this environment, using the Python PDB file.
