Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
448 Discussions
How to repair on macOS 13.5 a CONDA installlation with valid intelpython setup ?
cpetit
I have a good installation regarding `Intel python3.9` with all modules loading perfectly.
However, I have a bad behavior with the `conda` part of Intel OneAPI : I can't even do a `$ conda list` or a `$ conda env list` , I get the following message :
$ conda env list
__conda_exe:2: no such file or directory: /opt/intel/oneapi/intelpython/latest/bin/conda
So I have done the following export :
export CONDA_EXE=/opt/intel/oneapi/intelpython/latest/condabin/conda
And I redo the previous command, I get :
$ conda list
Traceback (most recent call last):
File "/opt/intel/oneapi/intelpython/latest/condabin/conda", line 12, in <module>
from conda.cli import main
ModuleNotFoundError: No module named 'conda'
I don't know what to do further to fix this Intel Conda installation.
If someone have already met this kind of issue of could see what's wrong ... I would like to avoid to remove all the Intel python distribution part.
**EDIT :** I forgot to mention that I have into my ~/.zshrc this part :
# !! Contents within this block are managed by 'conda init' !!
__conda_setup="$('/opt/intel/oneapi/intelpython/latest/condabin/conda' 'shell.zsh' 'hook' 2> /dev/null)"
if [ $? -eq 0 ]; then
eval "$__conda_setup"
else
if [ -f "/opt/intel/oneapi/intelpython/latest/etc/profile.d/conda.sh" ]; then
. "/opt/intel/oneapi/intelpython/latest/etc/profile.d/conda.sh"
else
export PATH="/opt/intel/oneapi/intelpython/latest/bin:$PATH"
fi
fi
unset __conda_setup
Alex_H_Sin
Hi Chris,
To clarify, you're calling conda from:
It is calling from Intel Distribution for Python, which is not supported according to the system requirements, along with all components of AI Kit.
To get conda working again, you need to launch a terminal without sourcing the oneAPI AI Kit setvars.sh script. Then when you type "which conda" it should show something like this, just as an example:
/home/<USER>/miniconda3/bin/conda
Best,
Alex
AthiraM_Intel
We are checking on this internally, we will get back to you with an update.
Alex_H_Sin
Hi Chris,
You are trying to use Intel Distribution for Python's conda on MacOS. MacOS is not supported on oneAPI AI Analytics Toolkit 2023.2: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-ai-analytics-toolkit-system-requirements.html
I recommend using the regular conda installed on your system.
Best,
Alex
cpetit
As I said, my current conda installation is not good.
Here the output of :
$ conda list
How to fix that ?
Which version of Conda are talking about when you say :
@Alex_H_Sin wrote:
Hi Chris,
Best,
Alex
Alex_H_Sin
Hi Chris,
Best,
Alex
Alex_H_Sin
Hi Chris, I have not heard from you in a while. If I don't hear back in 5 business days, I will be closing this ticket.
Best,
Alex
Alex_H_Sin
Hi Chris,
Since I got no response from you, I am closing this ticket. If you have a new issue, please submit a new ticket.
Alex
