Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
IDP 2018 update 2
Juan_K_
Since a clean install of Window 10 I have been using IDP instead of Anaconda.  The first install was IDP 2018 Update 1.  Since yesterday, upgrading to Update 2, i get this error running conda update conda or any conda command for that matter.
C:\Users\juank>conda update conda
Solving environment: failed
# >>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
    Traceback (most recent call last):
      File "C:\IntelPython3\lib\site-packages\conda\exceptions.py", line 812, in __call__
        return func(*args, **kwargs)
      File "C:\IntelPython3\lib\site-packages\conda\cli\main.py", line 78, in _main
        exit_code = do_call(args, p)
      File "C:\IntelPython3\lib\site-packages\conda\cli\conda_argparse.py", line 77, in do_call
        exit_code = getattr(module, func_name)(args, parser)
      File "C:\IntelPython3\lib\site-packages\conda\cli\main_update.py", line 14, in execute
        install(args, parser, 'update')
      File "C:\IntelPython3\lib\site-packages\conda\cli\install.py", line 235, in install
        force_reinstall=context.force,
      File "C:\IntelPython3\lib\site-packages\conda\core\solve.py", line 505, in solve_for_transaction
        force_remove, force_reinstall)
      File "C:\IntelPython3\lib\site-packages\conda\core\solve.py", line 438, in solve_for_diff
        final_precs = self.solve_final_state(deps_modifier, prune, ignore_pinned, force_remove)
      File "C:\IntelPython3\lib\site-packages\conda\core\solve.py", line 408, in solve_final_state
        return IndexedSet(index for d in solution)
      File "C:\IntelPython3\lib\site-packages\conda\_vendor\boltons\setutils.py", line 90, in __init__
        self.update(other)
      File "C:\IntelPython3\lib\site-packages\conda\_vendor\boltons\setutils.py", line 304, in update
        for o in other:
      File "C:\IntelPython3\lib\site-packages\conda\core\solve.py", line 408, in <genexpr>
    KeyError: Dist(channel='https://conda.anaconda.org/intel/zlib-1.2.11-vc14_intel_3.tar.bz2https://repo.continuum.io/pkgs/main/win-64', dist_name='conda-env-2.6.0-h36134e3_1', name='conda-env', version='2.6.0', build_string='h36134e3_1', build_number=1, base_url='intel/zlib-1.2.11-vc14_intel_3.tar.bz2https://repo.continuum.io/pkgs/main/win-64', platform='win-64')
`$ C:\IntelPython3\Scripts\conda update conda`
  environment variables:
                 CIO_TEST=<not set>
               CONDA_ROOT=C:\IntelPython3
                CUDA_PATH=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0
                 HOMEPATH=\Users\juank
      MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Common Files\Intel\Shared
                          Libraries\compiler\lib\mic
          NVTOOLSEXT_PATH=C:\Program Files\NVIDIA Corporation\NvToolsExt\
                     PATH=C:\IntelPython3\Library\bin;C:\IntelPython3\DLLs;C:\ProgramData\Oracle
                          \Java\javapath;C:\Program Files\NVIDIA GPU Computing
                          Toolkit\CUDA\v9.0\bin;C:\Program Files\NVIDIA GPU Computing
                          Toolkit\CUDA\v9.0\libnvvp;C:\Program Files (x86)\Common
                          Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Windows\system
                          32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowe
                          rShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:
                          \WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\Syste
                          m32\WindowsPowerShell\v1.0\;C:\Program Files\Git\cmd;C:\Program Files
                          (x86)\Wolfram Research\WolframScript\;C:\IntelPython3;C:\IntelPython3\
                          Scripts;C:\IntelPython3\bin;C:\Users\juank\AppData\Local\Microsoft\Win
                          dowsApps;C:\Program Files\Microsoft VS
                          Code\bin;C:\IntelPython\bin;;C:\IntelPython3;C:\IntelPython3\Scripts
             PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\Windows
                          PowerShell\v1.0\Modules
       REQUESTS_CA_BUNDLE=<not set>
            SSL_CERT_FILE=<not set>
     active environment : None
       user config file : C:\Users\juank\.condarc
 populated config files : C:\IntelPython3\.condarc
          conda version : 4.5.0
    conda-build version : not installed
         python version : 3.6.3.final.0
       base environment : C:\IntelPython3  (writable)
           channel URLs : https://conda.anaconda.org/intel/win-64
                          https://conda.anaconda.org/intel/noarch
                          https://repo.anaconda.com/pkgs/main/win-64
                          https://repo.anaconda.com/pkgs/main/noarch
                          https://repo.anaconda.com/pkgs/free/win-64
                          https://repo.anaconda.com/pkgs/free/noarch
                          https://repo.anaconda.com/pkgs/r/win-64
                          https://repo.anaconda.com/pkgs/r/noarch
                          https://repo.anaconda.com/pkgs/pro/win-64
                          https://repo.anaconda.com/pkgs/pro/noarch
                          https://repo.anaconda.com/pkgs/msys2/win-64
                          https://repo.anaconda.com/pkgs/msys2/noarch
          package cache : C:\IntelPython3\pkgs
                          C:\Users\juank\AppData\Local\conda\conda\pkgs
       envs directories : C:\IntelPython3\envs
                          C:\Users\juank\AppData\Local\conda\conda\envs
                          C:\Users\juank\.conda\envs
               platform : win-64
             user-agent : conda/4.5.0 requests/2.18.4 CPython/3.6.3 Windows/10 Windows/10.0.16299
          administrator : False
             netrc file : None
           offline mode : False
I am new to IDP, so apologies if my error is simple.
Juan.
gaston-hillar
Valued Contributor I
Juan,
I guess you are trying to update before activating an environment, i.e., you don't have an activated environment.
