Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Install/update downgrade intelpython3_core to 0.0.0.custom-0
Gobeil__jeremie
Almost all install produce this:
The following packages will be downloaded:
    package                    |            build
    ipywidgets-7.0.0           |     py36_intel_0          94 KB  intel
    widgetsnbextension-3.2.0   |           py36_0         1.7 MB  intel
                                           Total:         1.8 MB
The following NEW packages will be INSTALLED:
    intel-openmp:       2018.0.3-0
    ipywidgets:         7.0.0-py36_intel_0 intel       [intel]
    llvm-meta:          6.0.0-0            conda-forge
    widgetsnbextension: 3.2.0-py36_0       intel
The following packages will be UPDATED:
    mkl:                2018.0.3-intel_1   intel       --> 2018.0.3-1
The following packages will be DOWNGRADED:
    intelpython3_core:  2018.0.3-0         intel       --> 0.0.0.custom-0      intel
    openmp:             2018.0.3-intel_0   intel       --> 6.0.0-vc14_1        conda-forge [vc14 ]
    pip:                9.0.3-py36_0       intel       --> 9.0.1-py36_intel_1  intel       [intel]
    setuptools:         39.0.1-py36_0      intel       --> 27.2.0-py36_intel_0 intel       [intel]
I don't like and don't understand why intelpython3_core is downgraded to an unnumbered version, that OpenMP is overridden by the conda-forge version (conda-forge is last in the channels list), that mkl is override by the anaconda channels, and similar concern with pip and setuptools.
For now, I pinned mkl, intelpython3_core, OpenMP, pip, and setuptools to current version.
Is there a reason for all that and a way to not pin them and keep sane and current version?
gaston-hillar
Valued Contributor I
Jeremie,
Which operating system and version are you using?
Todd_T_Intel
Hello Jeremie,
In order to understand why the conda solver is making those choices, I need to see what packages are in your environment and what channels are configured.
Can you add the output of both "conda list" and "conda info"? Thank you.
Also, I apologize that it has taken so long for someone to respond to your initial request.
Best, Todd
Gobeil__jeremie
I removed and reinstall but I have the same problem.
When I try to install a package from intel, anaconda or conda-forge channels a whole bunch of things get updated/downgraded even if all the dependencies of the package are satisfied. Conda is up to date.
Here more info
OS Name    Microsoft Windows 10 Enterprise
Version    10.0.16299 Build 16299
# packages in environment at C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\envs\idp3:
# Name                    Version                   Build  Channel
asn1crypto                0.24.0             py36_intel_1  [intel]  intel
backcall                  0.1.0              py36_intel_0  [intel]  intel
backports                 1.0                py36_intel_6  [intel]  intel
bleach                    2.1.3              py36_intel_0  [intel]  intel
bzip2                     1.0.6             vc14_intel_14  [vc14 intel]  intel
certifi                   2018.1.18          py36_intel_0  [intel]  intel
cffi                      1.11.5             py36_intel_1  [intel]  intel
chardet                   3.0.4              py36_intel_0  [intel]  intel
colorama                  0.3.9              py36_intel_0  [intel]  intel
cryptography              2.2.2              py36_intel_1  [intel]  intel
cycler                    0.10.0             py36_intel_5  [intel]  intel
cython                    0.28.2             py36_intel_4  [intel]  intel
daal                      2018.0.3.20180405               0    intel
decorator                 4.3.0              py36_intel_0  [intel]  intel
entrypoints               0.2.3              py36_intel_0  [intel]  intel
freetype                  2.9                vc14_intel_1  [vc14 intel]  intel
get_terminal_size         1.0.0              py36_intel_5  [intel]  intel
hdf5                      1.10.1             vc14_intel_0  [vc14 intel]  intel
html5lib                  1.0.1              py36_intel_1  [intel]  intel
icc_rt                    2018.0.3                intel_0  [intel]  intel
idna                      2.6                py36_intel_0  [intel]  intel
impi_rt                   2018.0.3                intel_0  [intel]  intel
intelpython               2018.0.3                      0    intel
intelpython3_core         2018.0.3                      0    intel
intelpython3_full         2018.0.3                      1    intel
ipykernel                 4.6.1              py36_intel_0  [intel]  intel
ipyparallel               6.0.2              py36_intel_0  [intel]  intel
ipython                   6.3.1              py36_intel_1  [intel]  intel
ipython_genutils          0.2.0              py36_intel_0  [intel]  intel
ipywidgets                7.0.0              py36_intel_0  [intel]  intel
jedi                      0.12.0             py36_intel_0  [intel]  intel
jinja2                    2.9.6              py36_intel_0  [intel]  intel
jsonschema                2.6.0              py36_intel_0  [intel]  intel
jupyter                   1.0.0              py36_intel_5  [intel]  intel
jupyter_client            5.1.0              py36_intel_0  [intel]  intel
jupyter_console           5.1.0              py36_intel_0  [intel]  intel
jupyter_core              4.4.0              py36_intel_1  [intel]  intel
kiwisolver                1.0.1                    py36_1    intel
libpng                    1.6.34             vc14_intel_1  [vc14 intel]  intel
llvmlite                  0.23.0                   py36_0    intel
markupsafe                1.0                py36_intel_0  [intel]  intel
matplotlib                2.2.2           np114py36_intel_1  [intel]  intel
mistune                   0.7.4              py36_intel_1  [intel]  intel
mkl                       2018.0.3                intel_1    intel
mkl_fft                   1.0.2           np114py36_intel_0  [intel]  intel
mkl_random                1.0.1           np114py36_intel_0  [intel]  intel
mpi4py                    3.0.0              py36_intel_0  [intel]  intel
mpmath                    1.0.0              py36_intel_0  [intel]  intel
nbconvert                 5.2.1              py36_intel_0  [intel]  intel
nbformat                  4.4.0              py36_intel_0  [intel]  intel
nose                      1.3.7             py36_intel_16  [intel]  intel
notebook                  5.2.2              py36_intel_0  [intel]  intel
numba                     0.38.0          np114py36_intel_3  [intel]  intel
numexpr                   2.6.4           np114py36_intel_0  [intel]  intel
numpy                     1.14.3             py36_intel_0  [intel]  intel
openmp                    2018.0.3                intel_0    intel
openssl                   1.0.2o             vc14_intel_0  [vc14 intel]  intel
pandas                    0.22.0          np114py36_intel_4  [intel]  intel
pandocfilters             1.4.1              py36_intel_0  [intel]  intel
parso                     0.2.0              py36_intel_0  [intel]  intel
path.py                   11.0.1             py36_intel_0  [intel]  intel
pickleshare               0.7.4              py36_intel_1  [intel]  intel
pip                       9.0.3                    py36_0    intel
prompt_toolkit            1.0.15             py36_intel_0  [intel]  intel
pycparser                 2.18               py36_intel_0  [intel]  intel
pydaal                    2018.0.3.20180405 np114py36_intel_1  [intel]  intel
pygments                  2.2.0              py36_intel_1  [intel]  intel
pyopenssl                 17.5.0             py36_intel_0  [intel]  intel
pyparsing                 2.2.0              py36_intel_0  [intel]  intel
pysocks                   1.6.7              py36_intel_0  [intel]  intel
pytables                  3.4.2           np114py36_intel_4  [intel]  intel
python                    3.6.3                  intel_12  [intel]  intel
python-dateutil           2.6.0              py36_intel_3  [intel]  intel
pytz                      2018.4             py36_intel_0  [intel]  intel
pyyaml                    3.12               py36_intel_3  [intel]  intel
pyzmq                     16.0.2             py36_intel_4  [intel]  intel
requests                  2.18.4             py36_intel_0  [intel]  intel
scikit-learn              0.19.1          np114py36_intel_29  [intel]  intel
scipy                     1.0.1           np114py36_intel_3  [intel]  intel
setuptools                39.0.1                   py36_0    intel
simplegeneric             0.8.1              py36_intel_5  [intel]  intel
six                       1.11.0                   py36_2    intel
sqlite                    3.23.1             vc14_intel_0  [vc14 intel]  intel
sympy                     1.1.1              py36_intel_3  [intel]  intel
tbb                       2018.0.4                 vc14_0  [vc14]  intel
tbb4py                    2018.0.4            py36_vc14_0  [vc14]  intel
tcl                       8.6.4             vc14_intel_19  [vc14 intel]  intel
testpath                  0.3.1              py36_intel_0  [intel]  intel
tk                        8.6.4             vc14_intel_26  [vc14 intel]  intel
tornado                   4.5.2              py36_intel_0  [intel]  intel
traitlets                 4.3.2              py36_intel_1  [intel]  intel
urllib3                   1.22               py36_intel_0  [intel]  intel
vc                        14.0                          2    intel
vs2015_runtime            14.0.25420              intel_0  [intel]  intel
wcwidth                   0.1.7              py36_intel_5  [intel]  intel
webencodings              0.5.1                    py36_0    intel
wheel                     0.31.0             py36_intel_0  [intel]  intel
widgetsnbextension        3.2.0                    py36_0    intel
win_inet_pton             1.0.1              py36_intel_0  [intel]  intel
win_unicode_console       0.5                py36_intel_0  [intel]  intel
wincertstore              0.2                py36_intel_0  [intel]  intel
xz                        5.2.3              vc14_intel_0  [vc14 intel]  intel
zlib                      1.2.11             vc14_intel_3  [vc14 intel]  intel
     active environment : idp3
    active env location : C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\envs\idp3
            shell level : 2
       user config file : C:\Users\jgobeil\.condarc
 populated config files : C:\Users\jgobeil\.condarc
          conda version : 4.5.9
    conda-build version : 3.10.5
         python version : 3.6.5.final.0
       base environment : C:\Users\jgobeil\AppData\Local\Continuum\anaconda3  (writable)
           channel URLs : https://conda.anaconda.org/intel/win-64
                          https://conda.anaconda.org/intel/noarch
                          https://repo.anaconda.com/pkgs/main/win-64
                          https://repo.anaconda.com/pkgs/main/noarch
                          https://repo.anaconda.com/pkgs/free/win-64
                          https://repo.anaconda.com/pkgs/free/noarch
                          https://repo.anaconda.com/pkgs/r/win-64
                          https://repo.anaconda.com/pkgs/r/noarch
                          https://repo.anaconda.com/pkgs/pro/win-64
                          https://repo.anaconda.com/pkgs/pro/noarch
                          https://repo.anaconda.com/pkgs/msys2/win-64
                          https://repo.anaconda.com/pkgs/msys2/noarch
                          https://conda.anaconda.org/conda-forge/win-64
                          https://conda.anaconda.org/conda-forge/noarch
          package cache : C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\pkgs
                          C:\Users\jgobeil\AppData\Local\conda\conda\pkgs
       envs directories : C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\envs
                          C:\Users\jgobeil\AppData\Local\conda\conda\envs
                          C:\Users\jgobeil\.conda\envs
               platform : win-64
             user-agent : conda/4.5.9 requests/2.18.4 CPython/3.6.5 Windows/10 Windows/10.0.16299
          administrator : False
             netrc file : None
           offline mode : False
(idp3) C:\Users\jgobeil>conda update --all
Solving environment: done
# All requested packages already installed.
(idp3) C:\Users\jgobeil>conda install qgrid
## Package Plan ##
  environment location: C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\envs\idp3
  added / updated specs:
    - qgrid
    package                    |            build
    six-1.10.0                 |     py36_intel_8          20 KB  intel
    llvm-meta-6.0.0            |                0           3 KB  conda-forge
    distarray-0.6.0            |     py36_intel_4         282 KB  intel
    intelpython3_full-0.0.0.custom|                0           2 KB  intel
    numba-0.35.0               |     py36_intel_0         2.2 MB  intel
    intel-openmp-2018.0.3      |                0         1.7 MB
    intelpython3_core-0.0.0.custom|                0           2 KB  intel
    pycosat-0.6.3              |   py36hfa6e2cd_0          98 KB
    setuptools-27.2.0          |     py36_intel_0         558 KB  intel
    pip-9.0.1                  |     py36_intel_1         1.7 MB  intel
    openmp-6.0.0               |           vc14_1         308 KB  conda-forge
    qgrid-1.0.5                |           py36_1         1.3 MB
    mkl-2018.0.3               |                1       178.1 MB
    llvmlite-0.20.0            |     py36_intel_0         6.3 MB  intel
                                           Total:       192.5 MB
    distarray:         0.6.0-py36_intel_4       intel       [intel]
    menuinst:          1.4.14-py36hfa6e2cd_0
    pycosat:           0.6.3-py36hfa6e2cd_0
    pywin32:           223-py36hfa6e2cd_1
    qgrid:             1.0.5-py36_1
    intelpython3_full: 2018.0.3-1               intel       --> 0.0.0.custom-0      intel
    llvmlite:          0.23.0-py36_0            intel       --> 0.20.0-py36_intel_0 intel       [intel]
    numba:             0.38.0-np114py36_intel_3 intel       [intel] --> 0.35.0-py36_intel_0 intel       [intel]
    six:               1.11.0-py36_2            intel       --> 1.10.0-py36_intel_8 intel       [intel]
Proceed (/n)?
(idp3) C:\Users\jgobeil>conda info qgrid=="1.0.5 py36_1"
qgrid 1.0.5 py36_1
file name   : qgrid-1.0.5-py36_1.tar.bz2
version     : 1.0.5
build string: py36_1
build number: 1
channel     : https://repo.anaconda.com/pkgs/main/win-64
arch        : None
constrains  : ()
license     : Apache 2.0
license_family: Apache
md5         : 6acc7f17c09c8d6b81c3a595d031e8c2
platform    : None
subdir      : win-64
timestamp   : 1528148290926
url         : https://repo.anaconda.com/pkgs/main/win-64/qgrid-1.0.5-py36_1.tar.bz2
dependencies:
    ipywidgets >=7.0.0
    notebook >=4.0.0
    pandas >=0.18.0
    python >=3.6,<3.7.0a0
(idp3) C:\Users\jgobeil>conda config --show
add_anaconda_token: True
add_pip_as_python_dependency: True
aggressive_update_packages:
  - ca-certificates
  - certifi
  - openssl
allow_non_channel_urls: False
allow_softlinks: False
always_copy: False
always_softlink: False
always_yes: None
anaconda_upload: None
auto_update_conda: True
changeps1: True
channel_alias: https://conda.anaconda.org
channel_priority: True
channels:
  - intel
  - defaults
  - conda-forge
client_ssl_cert: None
client_ssl_cert_key: None
clobber: False
create_default_packages: []
custom_channels:
  pkgs/main: https://repo.anaconda.com
  pkgs/free: https://repo.anaconda.com
  pkgs/r: https://repo.anaconda.com
  pkgs/pro: https://repo.anaconda.com
  pkgs/msys2: https://repo.anaconda.com
custom_multichannels:
  defaults: ["https://repo.anaconda.com/pkgs/main", "https://repo.anaconda.com/pkgs/free", "https://repo.anaconda.com/pkgs/r", "https://repo.anaconda.com/pkgs/pro", "https://repo.anaconda.com/pkgs/msys2"]
  local: []
default_channels:
  - https://repo.anaconda.com/pkgs/main
  - https://repo.anaconda.com/pkgs/free
  - https://repo.anaconda.com/pkgs/r
  - https://repo.anaconda.com/pkgs/pro
  - https://repo.anaconda.com/pkgs/msys2
disallowed_packages: []
download_only: False
envs_dirs:
  - C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\envs
  - C:\Users\jgobeil\AppData\Local\conda\conda\envs
  - C:\Users\jgobeil\.conda\envs
force: False
json: False
local_repodata_ttl: 1
max_shlvl: 2
migrated_channel_aliases: []
no_dependencies: False
non_admin_enabled: True
notify_outdated_conda: True
offline: False
override_channels_enabled: True
path_conflict: clobber
pinned_packages: []
pkgs_dirs:
  - C:\Users\jgobeil\AppData\Local\Continuum\anaconda3\pkgs
  - C:\Users\jgobeil\AppData\Local\conda\conda\pkgs
proxy_servers: {}
quiet: False
remote_connect_timeout_secs: 9.15
remote_max_retries: 3
remote_read_timeout_secs: 60.0
report_errors: None
rollback_enabled: True
safety_checks: warn
shortcuts: True
show_channel_urls: None
ssl_verify: True
track_features: []
use_index_cache: False
use_pip: True
verbosity: 0
whitelist_channels: []
Gobeil__jeremie
(idp3) C:\>conda install nodejs
## Package Plan ##
    - nodejs
    package                    |            build
    nodejs-8.9.3               |       hd6b2f15_0        12.7 MB
    nodejs:            8.9.3-hd6b2f15_0
The following packages will be REMOVED:
Proceed (/n)? n
(idp3) C:\>conda update --all
Solving environment: failed
UnsatisfiableError: The following specifications were found to be in conflict:
  - intelpython3_full
  - intelpython3_full==2018.0.3-1
Use "conda info <package>" to see the dependencies for each package.
