Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Jupiter Notebooks for pyDAAL tutorials and code samples available on Github!
Sergey_M_Intel2
A Jupyter Notebook based tutorial series of using pyDAAL (the Python API for Intel DAAL) is now available on Github:
https://github.com/daaltces/pydaal-tutorials
It is designed for new users to quickly ramp up understanding of the pyDAAL API and usage model. There are only a few examples at this time, but we will gradually grow to cover more DAAL algorithms. You are more than welcome to use, share, fork, and contribute.
gaston-hillar
Valued Contributor I
Sergey,
It would be great if this thread is configured as a Sticky one. This way, anybody that enters the forum will know about these examples.
Ernest_B_1
Hi Sergey,
I have followed the pyDAAL installation as:
  1. conda update conda
  2. conda config --add channels intel
  3. conda create -n idp intelpython3_core python=3
  4. activate idp
  5. conda install mkl-devel
The whole installation was good. I'm using Eclipse IDE/PyDev 64-bit, Below is the code:
from daal.data_management import HomogenNumericTable
from utils import *
import numpy as np
import matplotlib
import matplotlib.pyplot as plt
def main():
    print("Testting Intel pyDAAL Framework!")
if __name__ == '__main__':
    main()
And here is the error. Let me know if I missed something?
  File "C:\Users\ebonat\eclipse-workspace\python_test\src\test.py", line 2, in <module>
ImportError: No module named 'daal'
Thanks for your time,
Ernest Bonat, Ph.D.
Senior Software Engineer
Senior Data Scientist
Ernest_B_1
Hi Sergey,
I have followed the steps to install Intel pyDAAL:
  4. activate idp
There was no error at all in any of the deployment.
I created a new Python project in Eclipse IDE/PyDev and wrote the following simple code:
from utils import *
import numpy as np
import matplotlib
def main():
    main()
Run the program and got the error:
Did I missed some thing?
Thank you,
Ernest Bonat, Ph.D.
Ernest_B_1
Hi Sergey,
Any help with this issue? I'm very excited to test the Intel pyDAAL library this long coming weekend.
Thank you for your time,
Ernest Bonat, Ph.D.
Christophe_H_Intel2
Hi Ernest,
PyDAAL is not part of the intelpython3_core package, so you will have to install it separately.
conda install -c intel pydaal
You will also find that matplotlib is not part of the core package.  You can install it separately too.
conda install -c intel matplotlib
Alternatively, you can get an environment with the full Intel distribution like this:
conda create -n idp -c intel intelpython3_full
Chris
Ernest_B_1
Hi Chris,
Thank you for your feedback. After:
Do I need to activate the idp as:
activate idp
Thank you for your help,
Ernest Bonat, Ph.D.
Christophe_H_Intel2
Hi Ernest,
Yes, you will need to activate the environment before using it.
Chris
Ernest_B_1
Hi Chris,
Is this one time setting only or I need to do it all the time after I turn my development laptop on to work on pyDAAL projects?
Thank
Ernest Bonat, Ph.D.
Christophe_H_Intel2
Ernest,
The "activate" script modifies your PATH for the current terminal session, so starting new sessions will reset your PATH to its default.
Chris
Ernest_B_1
Thank you, I go it!
Ernest Bonat, Ph.D.
Ernest_B_1
Hi
I have reviewed the following class files:
kmeans.py – no errors appear!
pca.py – an error occurred: “Undefined variable: warnings”
24 warnings.warn(method + ' method is not supported. Default method is used', UserWarning) – I believe the import is missed!
regression.py – the following errors occurred:
“Undefined variable from import: Batch_Float64DefaultDense”
165 ridge_training_alg = ridge_training.Batch_Float64DefaultDense() – I believe the import is missed!
85 warnings.warn(method + ' method is not supported. Default method is used', UserWarning) – I believe the import is missed!
svm_multi_class.py – the following errors occurred:
27 self._svm_training_alg = svm_training.Batch_Float64DefaultDense() – I believe the import is missed!
“Undefined variable from import: Batch_Float64DefaultDenseOneAgainstOne”
96  multiclass_prediction_alg = multiclass_prediction.Batch_Float64DefaultDenseOneAgainstOne() - I believe the import is missed!
utils.py – the following errors occurred:
“Undefined variable: BlockDescriptor”
6  bd = BlockDescriptor() - I believe the import is missed!
It should be:
bd = BlockDescriptor_Float64()
Let me know when theses syntax errors are fixed so I can the test the classes files.
Ernest Bonat, Ph.D.
Preethi_V_Intel
Hi Ernest,
We are currently reworking on the GitHub examples with the fix and adding new ones to sync with the upcoming pyDAAL 2018 version. These examples should be out end of next week or early week after.
Preethi
Ernest_B_1
Hi Preethi,
Thank you for letting me know. I'll be happy to test the upcoming pyDAAL 2018 version. Feel free to let me know when it's ready!
Ernest Bonat, Ph.D.
Ernest_B_1
Hi Sergey,
Two questions for you:
1. I have downloaded the pyDAAL 2018 library this morning. Do I need to uninstall the previous version or just install 2018 on top? Explain?
2. When will we have the GibHub Tutorials ready for testing 2018 initials release?
Ernest Bonat, Ph.D.
Christophe_H_Intel2
Hi Ernest,
If you're using conda to manage your environments, I would recommend creating a new environment with our 2018 packages.
conda create -n daal_2018 -c intel pydaal
. activate daal_2018
The other option is to use conda to update your current packages:
conda update -c intel --all
As for the Github tutorials, Preethi mentioned above that they would be ready by the end of this week or early next week.  She will let you know when they are posted.
Chris
Ernest_B_1
Thanks Chris,
What's the simple way to check which version of pyDAAL am I using in Python now?
Ernest Bonat, Ph.D.
Christophe_H_Intel2
Ernest,
To see the package versions of your current environment, run
conda list
You could also run
 python -c 'import daal; print(daal.__version__)'
Also, if you decide to update your current environment as opposed to creating a new one, be aware that if you were using python 3.5, Intel Python 2018 only includes python 3.6, so you would have to explicitly install python 3.6:
conda install python=3.6 -c intel
That said, I would still recommend creating a separate environment to test pydaal 2018.
Chris
Ernest_B_1
Thanks Chris,
I'll be creating a new separate environment to test pyDAAL 2018.
Ernest Bonat, Ph.D.
