Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
MKL for python
saikiran-427
how to install mkl for python.
Gopika_Intel
Thank you for the update. For the error, setting up oneAPI development environment (source setvars.sh) and installing Intel OneAPI Base Toolkit(if not installed) would solve it.
To source setvars.sh, run any one of the following commands according to the operating system you are using:
1. Linux
For root users:
source /opt/intel/oneapi/setvars.sh
For normal user installations:
source ~/intel/oneapi/setvars.sh
2. Windows
Run
 C:\Program Files (x86)\intel\oneapi\setvars.bat
Please refer this link to install the latest Intel OneAPI Base Toolkit: https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html
Hope this helps
Gopika
Gopika_Intel
Intel® oneAPI Math Kernel Library (oneMKL) is a computing math library of highly optimized, extensively threaded routines for applications that require maximum performance. The library provides Fortran and C programming language interfaces. If you want to build a native extension that directly uses the performance libraries, then you will need to obtain a development package that contains header files and static libraries. We have published them as conda packages for your convenience. Make sure the Intel channel is added to your conda configuration . Then install any of our available performance libraries using "conda install" as normal, such as:
conda install mkl-devel
These are the available packages mkl, mkl‑devel, mkl‑static, mkl‑include
For more information, please refer: https://software.intel.com/content/www/us/en/develop/articles/using-intel-distribution-for-python-with-anaconda.html#installing_the_Intel_Performance%20Libraries
Intel has been publishing wheels of packages like Numpy, Scipy and Scikit-learn to PyPI. These wheels have been built while linking against Intel MKL and include various optimizations.
If you want Scipy built with Intel MKL:
#Remove existing Numpy and/or Scipy:
pip uninstall numpy scipy -y
#Install scipy built with Intel MKL:
pip install intel-scipy
Gopika
saikiran-427
Thank you for the reply.
I'm have a C++ code and I'm combining it with python. The code has a header files "mkl.h", "fftw.h" .
I installed mkl using "sudo pip3 install mkl" command. But I did not find any mkl.h header file in my system. Can you tell me how to get those header files.
Thanks and Regards.
Gopika_Intel
1. Linux
For root users:
2. Windows
Run
Hope this helps
Gopika
saikiran-427
Is it possible to install only mkl module alone?
Gopika_Intel
Thank you for accepting it as a solution. You can download all standalone versions of modules in Intel OneAPI toolkits from here: https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#inpage-nav-11-5 . If you need any additional information, please submit a new question as this thread will no longer be monitored.
Gopika
nahtasurbhi
I have Win10 64Bit with Python 3.6.2 I have introduced scipy ,
I followed following advances :
Stage 1: Uninstall if you have any past adaptation of numpy, pip uninstall numpy
Stage 2 : Download numpy1.13.1+mklcp36cp36mwin_amd64.whl with MKL(Math Kernel Library) from beneath connect,
Stage 3: duplicate downloaded document into another area and dispatch order brief from that area.
Stage 4: run this order, pip introduce - U numpy-1.13.1+mkl-cp36-cp36m-win_amd64.whl
Stage 5: Now Download scipy library from,
Stage 6: Copy downloaded document into same area in which numpy is duplicated.
Stage 7: In CMD brief run this cmd, pip introduce scipy-0.19.1-cp36-cp36m-win_amd64.whl
Done!
