Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
RHEL intelpython bad gpg signature
HeinerD
Since a few days yum update on my RHEL 8 system fails with the following error message:
Error: Failed to download metadata for repo 'intelpython': repomd.xml GPG signature verification error: Bad GPG signature
yum update --nogpgcheck (runs okay)
From other similar posts I understood that this may be a problem on the intel side. All attempts that I tried so far, were not successful.
Any help would be appreciated very much.
RahulC_Intel
Hi Heiner, thank you for update. Kindly refer to the below link and follow the steps to setup the repository then install the Intel® AI Analytics Toolkit.
Link: https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-0/yum-dnf-zypper.html
Feel free to let us know, if the issue persists.
RahulC_Intel
Hi Heiner, we have sent you a private message. Kindly check your inbox.
RahulC_Intel
Hi Heiner, could you please share the below details for further investigation:
  • Operating System and Its Build number
  • Exact version of Intel® oneAPI toolkit.
  • Are you facing this issue after installing the product.
  • Did you tried to update the system? If yes, does the issue occur again.
  • Please share the screenshot of an error.
We would like to know,
HeinerD
Dear Rahul,
in the following I give you the requested information:
Operating System is RHEL 8.8:
# uname -a
Linux geoid1.ife.uni-hannover.de 4.18.0-477.27.1.el8_8.x86_64 #1 SMP Thu Aug 31 10:29:22 EDT 2023 x86_64 x86_64 x86_64 GNU/Linux
# cat /etc/redhat-release
Red Hat Enterprise Linux release 8.8 (Ootpa)
The problem is with intelpython not intel-oneapi (after installing the product(s)).
The following products are installed:
# yum list installed intel*
Updating Subscription Management repositories.
Installed Packages
intel-basekit.x86_64 2023.2.0-49384 @intel-oneAPI
intel-basekit-getting-started.noarch 2023.2.0-49384 @intel-oneAPI
intel-hpckit.x86_64 2023.2.0-49438 @intel-oneAPI
intel-hpckit-getting-started.noarch 2023.2.0-49438 @intel-oneAPI
intel-oneapi-advisor.x86_64 2023.2.0-49486 @intel-oneAPI
intel-oneapi-ccl-2021.10.0.x86_64 2021.10.0-49084 @intel-oneAPI
intel-oneapi-ccl-devel.x86_64 2021.10.0-49084 @intel-oneAPI
intel-oneapi-ccl-devel-2021.10.0.x86_64 2021.10.0-49084 @intel-oneAPI
intel-oneapi-common-licensing.noarch 2023.2.0-49462 @intel-oneAPI
intel-oneapi-common-licensing-2023.2.0.noarch 2023.2.0-49462 @intel-oneAPI
intel-oneapi-common-vars.noarch 2023.2.0-49462 @intel-oneAPI
intel-oneapi-compiler-cpp-eclipse-cfg.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-common-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-runtime-2023.2.0.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-compiler-dpcpp-cpp-runtime-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-dpcpp-eclipse-cfg.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-fortran.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-fortran-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-fortran-common-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-fortran-runtime-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-shared-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-shared-common-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-compiler-shared-runtime-2023.2.0.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-compiler-shared-runtime-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-condaindex.x86_64 2023.2.0-49417 @intel-oneAPI
intel-oneapi-dal-2023.2.0.x86_64 2023.2.0-49572 @intel-oneAPI
intel-oneapi-dal-common-2023.2.0.noarch 2023.2.0-49572 @intel-oneAPI
intel-oneapi-dal-common-devel-2023.2.0.noarch 2023.2.0-49572 @intel-oneAPI
intel-oneapi-dal-devel.x86_64 2023.2.0-49572 @intel-oneAPI
intel-oneapi-dal-devel-2023.2.0.x86_64 2023.2.0-49572 @intel-oneAPI
intel-oneapi-dev-utilities.x86_64 2021.10.0-49423 @intel-oneAPI
intel-oneapi-dev-utilities-2021.10.0.x86_64 2021.10.0-49423 @intel-oneAPI
intel-oneapi-dev-utilities-eclipse-cfg.noarch 2021.10.0-49423 @intel-oneAPI
intel-oneapi-diagnostics-utility.x86_64 2022.4.0-49091 @intel-oneAPI
intel-oneapi-dnnl.x86_64 2023.2.0-49516 @intel-oneAPI
intel-oneapi-dnnl-devel.x86_64 2023.2.0-49516 @intel-oneAPI
intel-oneapi-dpcpp-cpp-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-dpcpp-ct.x86_64 2023.2.0-49330 @intel-oneAPI
intel-oneapi-dpcpp-ct-2023.2.0.x86_64 2023.2.0-49330 @intel-oneAPI
intel-oneapi-dpcpp-ct-eclipse-cfg.noarch 2023.2.0-49330 @intel-oneAPI
intel-oneapi-dpcpp-debugger.x86_64 2023.2.0-49330 @intel-oneAPI
intel-oneapi-dpcpp-debugger-2023.2.0.x86_64 2023.2.0-49330 @intel-oneAPI
intel-oneapi-embree.x86_64 4.1.0-49414 @intel-oneAPI
intel-oneapi-embree-4.1.0.x86_64 4.1.0-49414 @intel-oneAPI
intel-oneapi-icc-eclipse-plugin-cpp-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-inspector.x86_64 2023.2.0-49301 @intel-oneAPI
intel-oneapi-ipp-2021.9.0.x86_64 2021.9.0-49452 @intel-oneAPI
intel-oneapi-ipp-common-2021.9.0.noarch 2021.9.0-49452 @intel-oneAPI
intel-oneapi-ipp-common-devel-2021.9.0.noarch 2021.9.0-49452 @intel-oneAPI
intel-oneapi-ipp-devel.x86_64 2021.9.0-49452 @intel-oneAPI
intel-oneapi-ipp-devel-2021.9.0.x86_64 2021.9.0-49452 @intel-oneAPI
intel-oneapi-ippcp-2021.8.0.x86_64 2021.8.0-49490 @intel-oneAPI
intel-oneapi-ippcp-common-2021.8.0.noarch 2021.8.0-49490 @intel-oneAPI
intel-oneapi-ippcp-common-devel-2021.8.0.noarch 2021.8.0-49490 @intel-oneAPI
intel-oneapi-ippcp-devel.x86_64 2021.8.0-49490 @intel-oneAPI
intel-oneapi-ippcp-devel-2021.8.0.x86_64 2021.8.0-49490 @intel-oneAPI
intel-oneapi-ispc.x86_64 1.20.0-49477 @intel-oneAPI
intel-oneapi-ispc-1.20.0.x86_64 1.20.0-49477 @intel-oneAPI
intel-oneapi-itac.x86_64 2021.10.0-11 @intel-oneAPI
intel-oneapi-itac-2021.10.0.x86_64 2021.10.0-11 @intel-oneAPI
intel-oneapi-libdpstd-devel.x86_64 2022.2.0-49284 @intel-oneAPI
intel-oneapi-libdpstd-devel-2022.2.0.x86_64 2022.2.0-49284 @intel-oneAPI
intel-oneapi-mkl-2023.2.0.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-mkl-common-2023.2.0.noarch 2023.2.0-49495 @intel-oneAPI
intel-oneapi-mkl-common-devel-2023.2.0.noarch 2023.2.0-49495 @intel-oneAPI
intel-oneapi-mkl-devel.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-mkl-devel-2023.2.0.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-mpi-2021.10.0.x86_64 2021.10.0-49371 @intel-oneAPI
intel-oneapi-mpi-devel.x86_64 2021.10.0-49371 @intel-oneAPI
intel-oneapi-mpi-devel-2021.10.0.x86_64 2021.10.0-49371 @intel-oneAPI
intel-oneapi-oidn-2.0.0.x86_64 2.0.0-49414 @intel-oneAPI
intel-oneapi-openmp-2023.2.0.x86_64 2023.2.0-49495 @intel-oneAPI
intel-oneapi-openmp-2023.2.1.x86_64 2023.2.1-16 @intel-oneAPI
intel-oneapi-openmp-common-2023.2.0.noarch 2023.2.0-49495 @intel-oneAPI
intel-oneapi-openmp-common-2023.2.1.noarch 2023.2.1-16 @intel-oneAPI
intel-oneapi-openpgl.x86_64 0.5.0-49408 @intel-oneAPI
intel-oneapi-openpgl-0.5.0.x86_64 0.5.0-49408 @intel-oneAPI
intel-oneapi-openvkl.x86_64 1.3.2-49396 @intel-oneAPI
intel-oneapi-openvkl-1.3.2.x86_64 1.3.2-49396 @intel-oneAPI
intel-oneapi-ospray-2.12.0.x86_64 2.12.0-49389 @intel-oneAPI
intel-oneapi-ospray-studio.x86_64 0.12.1-49375 @intel-oneAPI
intel-oneapi-ospray-studio-0.12.1.x86_64 0.12.1-49375 @intel-oneAPI
intel-oneapi-rkcommon-1.11.0.x86_64 1.11.0-49407 @intel-oneAPI
intel-oneapi-rkutil.x86_64 1.8.1-49486 @intel-oneAPI
intel-oneapi-rkutil-1.8.1.x86_64 1.8.1-49486 @intel-oneAPI
intel-oneapi-tbb-2021.10.0.x86_64 2021.10.0-49541 @intel-oneAPI
intel-oneapi-tbb-common-2021.10.0.noarch 2021.10.0-49541 @intel-oneAPI
intel-oneapi-tbb-common-devel-2021.10.0.noarch 2021.10.0-49541 @intel-oneAPI
intel-oneapi-tbb-devel.x86_64 2021.10.0-49541 @intel-oneAPI
intel-oneapi-tbb-devel-2021.10.0.x86_64 2021.10.0-49541 @intel-oneAPI
intel-oneapi-vtune.x86_64 2023.2.0-49484 @intel-oneAPI
intel-oneapi-vtune-eclipse-plugin-vtune.noarch 2023.2.0-49484 @intel-oneAPI
intel-renderkit.x86_64 2023.2.0-49365 @intel-oneAPI
intel-renderkit-getting-started.noarch 2023.2.0-49365 @intel-oneAPI
intelpython2.x86_64 2019.4-088 @intelpython
intelpython3.x86_64 2020.2-902 @intelpython
Command "dnf update" creates the error message, "dnf clean all" does not help, see below:
# dnf clean all
30 files removed
# dnf update
dell-system-update_independent 135 kB/s | 208 kB 00:01
dell-system-update_dependent 117 kB/s | 276 kB 00:02
Extra Packages for Enterprise Linux 8 - x86_64 25 MB/s | 16 MB 00:00
Intel oneAPI repository 30 MB/s | 25 MB 00:00
Intel(R) Distribution for Python* for Linux OS 3.4 kB/s | 287 B 00:00
Intel(R) Distribution for Python* for Linux OS 58 kB/s | 1.9 kB 00:00
Intel(R) Distribution for Python* for Linux OS 3.6 kB/s | 287 B 00:00
# dnf update
Intel(R) Distribution for Python* for Linux OS 3.2 kB/s | 287 B 00:00
Intel(R) Distribution for Python* for Linux OS 59 kB/s | 1.9 kB 00:00
Intel(R) Distribution for Python* for Linux OS 3.7 kB/s | 287 B 00:00
The repo files on my system are as follows:
# cat /etc/yum.repos.d/intel-oneapi.repo
[intel-oneAPI]
name=Intel oneAPI repository
baseurl=https://yum.repos.intel.com/oneapi
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
# cat /etc/yum.repos.d/intelproducts.repo
[intelpython]
name=Intel(R) Distribution for Python* for Linux OS
baseurl=https://yum.repos.intel.com/intelpython
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
[intel-daal-repo]
name=Intel(R) Data Analytics Acceleration Library
baseurl=https://yum.repos.intel.com/daal
enabled=1
gpgcheck=1
repo_gpgcheck=1
[intel-ipp-repo]
name=Intel(R) Integrated Performance Primitives
baseurl=https://yum.repos.intel.com/ipp
enabled=1
gpgcheck=1
repo_gpgcheck=1
[intel-mkl-repo]
name=Intel(R) Math Kernel Library
baseurl=https://yum.repos.intel.com/mkl
enabled=1
gpgcheck=1
repo_gpgcheck=1
[intel-tbb-repo]
name=Intel(R) Threading Building Blocks
baseurl=https://yum.repos.intel.com/tbb
enabled=1
gpgcheck=1
repo_gpgcheck=1
[intel-mpi-repo]
name=Intel(R) MPI Library
baseurl=https://yum.repos.intel.com/mpi
enabled=1
gpgcheck=1
repo_gpgcheck=1
This should be all info needed.
With best regards,
Heiner
RahulC_Intel
RahulC_Intel
Hi Heiner, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
