Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Spyder IDE
RPint
Has anyone succeeded to install Spyder with Intel Python?
I am not used to conda, but whenever I try:
C:\IntelPython35>Scripts\conda install spyder
Fetching package metadata: ......
Solving package specifications: ....
The following specifications were found to be in conflict:
  - spyder -> pyqt
Use "conda info <package>" to see the dependencies for each package.
Then, if I try pyqt, it complains on qt and then, a cryptic message:
C:\IntelPython35>Scripts\conda install qt
  - qt -> @vc10
  - qt -> @vc14
  - qt -> @vc9
I do have Visual Studio 2015 configured in my system, and I also used the correct system variables...
What should I try next?
Rafael
Todd_T_Intel
Rafael,
Thank you for trying the Intel(R) Distribution for Python.
Unfortunately, it looks like our current distribution is not compatible with Continuum's qt on Windows. The @strings in those cryptic "qt -> @vc10" lines refer to conda "features" that must be installed in order for conda to consider the package compatible. The "vc9", "vc10", and "vc14" features are currently only implemented with the installation of Continuum's python.
Our upcoming Beta update should resolve this problem and allow installation of packages such as qt from Continuum.
Until then, your best option is probably to install pyqt manually and then "pip install spyder".
Be Well,
Todd
Todd_T_Intel
Rafael,
Be Well,
Todd
RPint
It is with pleasure that I inform you that Intel Python Beta is able to install pyqt using Conda! You just need to setup the IntelPython environment in Conda.
Thanks Intel!
Rafael Pinto
karczmarczuk__jerzy
After having read some posts here, and having developed a serious allergy to dependency conflicts in Anaconda, I installed the Intel distribution separately, in its own environment, and with all needed packages, including pyqt (conda install loads a different version of qt, 5.9.6, anaconda has 5.9.7, but "intel conda" refuses to update it). The "use('Qt5Agg')" in Matplotlib is accepted, does something, and then, trying to import QtGui, and other entities, it issues:
File "C:\intelpython3\lib\site-packages\matplotlib\backends\qt_compat.py", line 158, in <module> raise ImportError("Failed to import any qt binding") ImportError: Failed to import any qt binding
More concretely, executing manually some commands:
- PyQt5 loads without complaining. And then:
from PyQt5 import QtCore, QtGui, QtWidgets
bombs, with
ImportError: DLL load failed: Le module spécifié est introuvable.
Perhaps I have forgotten to install something, but what?...
Thanks. J.
sylvian_k_
I tried to install spyder with the last 2019 v. 3
and I got this:
menuinst Exception
LinkError: post-link script failed for package defaults::ipykernel-4.10.0-py27_0
In my opinion Intel makes too much noise with their python. Anaconda is also based on the mkl libraries.
sylvian_k_
The previous post was based on "scripts\conda.exe install spyder" (in python_2.7).
I tried also:
"python -m pip install spider"
and apparently a spyder.exe appeared in the scripts folder (all this in Windows10).
But, trying to execute the above spider.exe I am getting:
"python2.exe - Ordinal not found.
The ordinal 242 could not be located in the dynamic link library D:\intelpython2\Library\mkl_intel_thread.dll."
Now, I guess this intelpython2 is a 64 bit application, because I am getting the same error from the last Anaconda2 64 bit. Anaconda2 32 bit is working without errors.
Bulavas__Viktoras
Looks like Spyder is not working after the recent update with Intel. Again.
conda install spyder -c intel --no-update-deps
Collecting package metadata: done
Solving environment: \
The environment is inconsistent, please check the package plan carefully
The following packages are causing the inconsistency:
  - intel/win-64::intelpython3_full==0.0.0.custom=0
Bulavas__Viktoras
Looks like Spyder is not an option with Intel performance libraries:
