Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
TBB module: Unleash parallel performance of Python programs
Anton_M_Intel
Dear users of Intel Distribution for Python, let me introduce TBB module which enables additional performance for multi-threaded Python programs!
Please follow this link in order to read the blog article.
// Anton
sergio_r_
Hi Anton, I was able to successfully run your code. The test results are as follows:
$ python3 bench.py
25.36649799346924
$ python3 -m TBB bench.py
22.13143277168274
$ python3 bench.py
26.60333490371704
21.826074361801147
Not sure how to make a proper interpretation of them.
Is there a performance test suite available for this python beta (2017) distribution?
Sergio
Andrew_D_3
Anton,
may be worth mentioning that TBB will only offload to the Phi card if you install the latest version of Intel Python (l_python27_bu_2017.0.018). The version that was available when you posted the article does not work.
Anton_M_Intel
Hi Sergio,
Thank you a lot for getting back to me with your results! If the numbers represent a time unit (my bench from the blog prints time), it is easy to interpret it as TBB helps with this benchmark on your machine. Do you have any other concerns or more questions here?
We don't have other benchmarks except we published in blogs. You can use publicly available/standard python benchmarks.
Anton
Anton_M_Intel
Andrew, TBB does nothing w.r.t. offloading. It is only about managing threads within the same process where it is enabled.
But you are right that offloading was enabled for MKL in Intel Distribution for Python 2017 Beta Update 1.
Mounagurusamy__Guruv
I am working on an OpenCV DNN CAFFE code for detecting humans in CCTV cameras, Can you please let me know, if I can use TBB to parallelize Python.
Anton_M_Intel
Short answer: no, TBB is not for making interpreted Python code parallel.
Please use regular approaches to parallelism in Python like multiprocessing.pool, Joblin, Dask, Ray, etc. TBB for Python helps to compose them better, without exposing it's C++ parallel programming model to Python.
