Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Trouble with opencv-python-headless
Orion_P_
I'm trying to use the opencv-python-headless conda package for Python 3.9 on EL8 and getting the following:
Python 3.9.19 (tags/v3.9.19-26-g2d3a350f043-dirty:2d3a350f043, May 25 2024, 00:41:40)
[GCC 13.2.0] :: Intel Corporation on linux
(null)Type "help", "copyright", "credits" or "license" for more information.
Intel(R) Distribution for Python is brought to you by Intel Corporation.
Please check out: https://software.intel.com/en-us/python-distribution
>>> import cv2
  File "<stdin>", line 1, in <module>
  File "/opt/anaconda/envs/scipy39-intel/lib/python3.9/site-packages/cv2/__init__.py", line 181, in <module>
    bootstrap()
  File "/opt/anaconda/envs/scipy39-intel/lib/python3.9/site-packages/cv2/__init__.py", line 153, in bootstrap
    native_module = importlib.import_module("cv2")
  File "/opt/anaconda/envs/scipy39-intel/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
ImportError: /lib64/libm.so.6: version `GLIBC_2.29' not found (required by /opt/anaconda/envs/scipy39-intel/lib/python3.9/site-packages/cv2/cv2.abi3.so)
Is this package not supported for EL8?
StefR_Intel
The error message you're encountering suggests that the opencv-python-headless package is trying to use  GLIBC_2.29, but your system's glibc version is older than that. Please consider opening this issue here: https://github.com/opencv/opencv/issues.
Stef
Orion_P_
That is clearly the issue - but the cause is how it was compiled, not with the upstream source.  So the issue would need to be resolved in how the package was built, which is presumably Intel's responsibility since it comes from the Intel conda repository.
Also, the package is also only available for Python 3.9, 3.10, and 3.11 - not 3.12.  Is it really a supported package?
StefR_Intel
It appears that opencv-python-headless is a dependency of another library that is not associated with the Intel® Distribution for Python*, and may have different system requirements. Consider installing it via the conda-forge channel instead. You can find more information about system requirements, recommended installation options, and the components included in the Intel® Distribution for Python* here. If you have any further questions about the Intel® Distribution for Python* or encounter any issues, please don’t hesitate to contact us.
Stef
