Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
What's New: Intel® Distribution for Python* 2025.3
StefR_Intel
Data Parallel Control Library* includes the following improvements:
  • Implemented tensor.isin membership test
  • Allow NumPy arrays for advanced indexing
  • Reduced binary size by making constexpr variables in headers inline and others static, and removing all anonymous namespaces from headers
  • Fixed DLL search path when initializing dpctl, fixing failure to see devices when importing in venv on Windows
  • Fixed failure to copy arrays of double dtype from device with double precision to a device without double precision
Data Parallel Extension for Numpy* includes the following improvements:
  • Added implementation of dpnp.piecewise, dpnp.special.erf, dpnp.special.erfc, dpnp.linalg.lu_solve and dpnp.linalg.lu_factor functions
  • Implemented new dpnp.ndarray.view, dpnp.ndarray.__contains__ methods and dpnp.ndarray.data, dpnp.ndarray.data.ptr attributes to improve CuPy compatibility
  • Improved performance of dpnp.isclose, dpnp.linalg.det and dpnp.linalg.slogdet functions
  • Improved performance for a specialized matrix multiplication where the result is a symmetric matrix
  • The order of individual FFTs over axes for dpnp.fft.irfftn is changed to be in forward order
  • The intermediate steps of ND FFT are updated to perform in-place FFT
  • dpnp.size accepts a tuple of integers for axes keyword
  • dpnp.pad accepts a dictionary for pad_width keyword
  • The license handling is aligned with PEP-639
  • The new dpnp release is compatible with NumPy 2.3.3
  • Including fixes in:
    • dpnp.ndarray constructor passed with dpnp.ndarray.data value for buffer keyword
    • dpnp.random functions to allow any value of size keyword where each element is castable to Py_ssize_t type
    • dpnp.linalg.cond to always return a real data type
    • dpnp.unique with 1D input array and axis=0, equal_nan=True passed where the produced result didn't collapse the NaNs
    • dpnp.resize with unsigned integer size
Intel® Distribution for Python's NumPy-based Python interface to Intel® oneAPI Math Kernel Library (oneMKL) Fourier Transform Functions includes following improvements:
  • Permit building with Python 3.13
  • Removed scipy.fftpack interfaced (deprecated in scipy)
  • Resolved a bug in N-D FFTs when given out and s keyword arguments
Intel® Distribution for Python's mkl_umath package implementing NumPy's UFuncs based on SVML and MKL VML:
  • Changed to dynamic linking and to use LP64, permitting arrays larger than 2**31
  • Added new MKL function implementations
  • Removed MKL implementations for functions which showed no performance improvement compared to stock NumPy pending further evaluation
Other improvements:
  • Intel® Distribution for Python's package for run-time control of Intel® oneAPI Math Kernel Library (oneMKL) now permits building with Python 3.14
