Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
a problem of using Intel distribution for python
Xuwen_T_Intel
I helped someone else to post his problem here about the use of Intel distribution for Python. He used anaconda2 to install Intel distribution for python and encountered a problem when he tried to execute his code. The error messages are listed below and his problem is in CorrMM. Please provide your precious suggestions for solving this problem. His code used Theano and he installed the latest Intel distribution for python.
  File "./deepMedicRun", line 141, in <module>
    deepMedicTest.deepMedicTestMain(absPathToTestConf, absPathToCnnModelGivenInCmdLine)
  File "/home/intel_ai/deepmedic/deepmedic/frontEndModules/deepMedicTest.py", line 302, in deepMedicTestMain
    cnn3dInstance.compileTestAndVisualisationFunction(*testSessionParameters.getTupleForCompilationOfTestFunc())
  File "/home/intel_ai/deepmedic/deepmedic/cnn3d.py", line 626, in compileTestAndVisualisationFunction
    givens=givensSet
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/compile/function.py", line 326, in function
    output_keys=output_keys)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/compile/pfunc.py", line 484, in pfunc
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/compile/function_module.py", line 1786, in orig_function
    defaults)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/compile/function_module.py", line 1650, in create
    input_storage=input_storage_lists, storage_map=storage_map)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/link.py", line 699, in make_thunk
    storage_map=storage_map)[:3]
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/vm.py", line 1051, in make_all
    no_recycling))
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/op.py", line 932, in make_thunk
    no_recycling)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/op.py", line 833, in make_c_thunk
    output_storage=node_output_storage)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cc.py", line 1190, in make_thunk
    keep_lock=keep_lock)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cc.py", line 1131, in __compile__
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cc.py", line 1589, in cthunk_factory
    key=key, lnk=self, keep_lock=keep_lock)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cmodule.py", line 1145, in module_from_key
    module = lnk.compile_cmodule(location)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cc.py", line 1492, in compile_cmodule
    preargs=preargs)
  File "/root/.local/lib/python2.7/site-packages/Theano-0.9.0.dev2-py2.7.egg/theano/gof/cmodule.py", line 2313, in compile_str
    (status, compile_stderr.replace('\n', '. ')))
Exception: ('The following error happened while compiling the node', CorrMM{valid, (1, 1), (1, 1)}(Reshape{4}.0, Subtensor{::, ::, ::int64, ::int64}.0), '\n', 'Compilation failed (return status=1):
/bin/ld: cannot find -lmkl_rt. collect2: error: ld returned 1 exit status. ', '[CorrMM{valid, (1, 1), (1, 1)}(<TensorType(float32, 4D)>, <TensorType(float32, 4D)>)]')
Xuwen_T_Intel
I checked the Theano website and found that CorrMM was carried out on the GPU in Theano 0.8. Has this API been supported by MKL in Intel Python distribution update 3 already?
Peng_Z_Intel
CorrMM is the original CPU OP and the Theano doesn't find the mkl_rt.so in the library path from your log.
Please add the path of mkl_rt.so  into LIBRARY_PATH.
Todd_T_Intel
In case it is not clear, libmkl_rt.so is found in <python_env_root>/lib in the Intel Distribution for Python.
If this does not resolve the problem, it is very helpful to post the output of "conda info" and "conda list", which tells a great deal about the environment.
-Todd
Xuwen_T_Intel
Hi, Peng and Todd
Thanks for the suggestions. We will post the output of "conda list"  and "conda info" at a later time.
Anyway we ever used the "locate libmkl_rt.so" and found several libmkl_rt.so files in different directories.
 find: `/run/user/1000/gvfs': Permission denied
/home/intel_ai/anaconda2/pkgs/mkl-2017.0.3-intel_6/lib/libmkl_rt.so
/home/intel_ai/anaconda2/pkgs/mkl-2017.0.1-0/lib/libmkl_rt.so
/home/intel_ai/anaconda2/envs/idp2/lib/libmkl_rt.so
/home/intel_ai/anaconda2/lib/libmkl_rt.so
/opt/intel/compilers_and_libraries_2017.2.174/Linux
Xuwen_T_Intel
Hi, Todd
The output of "conda info" and "conda list" is list below.
[intel_ai@localhost deepmedic]$ conda info
Current conda install:
               platform : linux-64
          conda version : 4.3.21
       conda is private : False
      conda-env version : 4.3.21
    conda-build version : not installed
         python version : 2.7.13.final.0
       requests version : 2.14.2
       root environment : /home/intel_ai/anaconda2  (writable)
    default environment : /home/intel_ai/anaconda2
       envs directories : /home/intel_ai/anaconda2/envs
                          /home/intel_ai/.conda/envs
          package cache : /home/intel_ai/anaconda2/pkgs
                          /home/intel_ai/.conda/pkgs
           channel URLs : https://conda.anaconda.org/intel/linux-64
                          https://conda.anaconda.org/intel/noarch
                          https://conda.anaconda.org/conda-forge/linux-64
                          https://conda.anaconda.org/conda-forge/noarch
                          https://repo.continuum.io/pkgs/free/linux-64
                          https://repo.continuum.io/pkgs/free/noarch
                          https://repo.continuum.io/pkgs/r/linux-64
                          https://repo.continuum.io/pkgs/r/noarch
                          https://repo.continuum.io/pkgs/pro/linux-64
                          https://repo.continuum.io/pkgs/pro/noarch
            config file : /home/intel_ai/.condarc
             netrc file : None
           offline mode : False
             user-agent : conda/4.3.21 requests/2.14.2 CPython/2.7.13 Linux/3.10.0-327.36.3.el7.xppsl_1.5.0.4036.x86_64 CentOS Linux/7.3.1611 glibc/2.17
                UID:GID : 1000:1000
_license                  1.1                      py27_1
alabaster                 0.7.10                   py27_0
anaconda                  4.4.0               np112py27_0
anaconda-client           1.6.3                    py27_0
anaconda-navigator        1.6.2                    py27_0
anaconda-project          0.6.0                    py27_0
asn1crypto                0.22.0                   py27_0
astroid                   1.4.9                    py27_0
astropy                   1.3.2               np112py27_0
babel                     2.4.0                    py27_0
backports                 1.0                      py27_0
backports_abc             0.5                      py27_0
beautifulsoup4            4.6.0                    py27_0
bitarray                  0.8.1                    py27_0
blaze                     0.10.1                   py27_0
bleach                    1.5.0                    py27_0
bokeh                     0.12.5                   py27_1
boto                      2.46.1                   py27_0
bottleneck                1.2.1               np112py27_0
cairo                     1.14.8                        0
cdecimal                  2.3                      py27_2
cffi                      1.10.0                   py27_0
chardet                   3.0.3                    py27_0
click                     6.7                      py27_0
cloudpickle               0.2.2                    py27_0
clyent                    1.2.2                    py27_0
colorama                  0.3.9                    py27_0
conda                     4.3.21                   py27_0    conda-forge
conda-env                 2.6.0                         0    conda-forge
configparser              3.5.0                    py27_0
contextlib2               0.5.5                    py27_0
cryptography              1.8.1                    py27_0
cuda80                    1.0                           0    soumith
curl                      7.52.1                        0
cycler                    0.10.0                   py27_0
cython                    0.25.2                   py27_0
cytoolz                   0.8.2                    py27_0
dask                      0.14.3                   py27_1
datashape                 0.5.4                    py27_0
dbus                      1.10.10                       0
decorator                 4.0.11                   py27_0
dicom                     0.9.9.post1               <pip>
distributed               1.16.3                   py27_0
docutils                  0.13.1                   py27_0
entrypoints               0.2.2                    py27_1
enum34                    1.1.6                    py27_0
et_xmlfile                1.0.1                    py27_0
expat                     2.1.0                         0
fastcache                 1.0.2                    py27_1
flask                     0.12.2                   py27_0
flask-cors                3.0.2                    py27_0
fontconfig                2.12.1                        3
freetype                  2.5.5                         2
funcsigs                  1.0.2                    py27_0
functools32               3.2.3.2                  py27_0
futures                   3.1.1                    py27_0
get_terminal_size         1.0.0                    py27_0
gevent                    1.2.1                    py27_0
glib                      2.50.2                        1
greenlet                  0.4.12                   py27_0
grin                      1.2.1                    py27_3
gst-plugins-base          1.8.0                         0
gstreamer                 1.8.0                         0
h5py                      2.7.0               np112py27_0
harfbuzz                  0.9.39                        2
hdf5                      1.8.17                        1
heapdict                  1.0.0                    py27_1
html5lib                  0.999                    py27_0
icu                       54.1                          0
idna                      2.5                      py27_0
imagesize                 0.7.1                    py27_0
ipaddress                 1.0.18                   py27_0
ipykernel                 4.6.1                    py27_0
ipython                   5.3.0                    py27_0
ipython_genutils          0.2.0                    py27_0
ipywidgets                6.0.0                    py27_0
isort                     4.2.5                    py27_0
itsdangerous              0.24                     py27_0
jbig                      2.1                           0
jdcal                     1.3                      py27_0
jedi                      0.10.2                   py27_2
jinja2                    2.9.6                    py27_0
jpeg                      9b                            0
jsonschema                2.6.0                    py27_0
jupyter                   1.0.0                    py27_3
jupyter_client            5.0.1                    py27_0
jupyter_console           5.1.0                    py27_0
jupyter_core              4.3.0                    py27_0
lazy-object-proxy         1.2.2                    py27_0
libffi                    3.2.1                         1
libgcc                    4.8.5                         2
libgfortran               3.0.0                         1
libiconv                  1.14                          0
libpng                    1.6.27                        0
libprotobuf               3.2.0                         0    anaconda
libsodium                 1.0.10                        0
libtiff                   4.0.6                         3
libtool                   2.4.2                         0
libxcb                    1.12                          1
libxml2                   2.9.4                         0
libxslt                   1.1.29                        0
llvmlite                  0.18.0                   py27_0
locket                    0.2.0                    py27_1
lxml                      3.7.3                    py27_0
markupsafe                0.23                     py27_2
matplotlib                2.0.2               np112py27_0
mistune                   0.7.4                    py27_0
mkl                       2017.0.1                      0
mkl-service               1.1.2                    py27_3
mock                      2.0.0                    py27_0    anaconda
mpmath                    0.19                     py27_1
msgpack-python            0.4.8                    py27_0
multipledispatch          0.4.9                    py27_0
navigator-updater         0.1.0                    py27_0
nbconvert                 5.1.1                    py27_0
nbformat                  4.3.0                    py27_0
networkx                  1.11                     py27_0
nibabel                   2.1.0                    py27_0    conda-forge
nltk                      3.2.3                    py27_0
nose                      1.3.7                    py27_1
notebook                  5.0.0                    py27_0
numba                     0.33.0              np112py27_0
numexpr                   2.6.2               np112py27_0
numpy                     1.12.1                   py27_0
numpydoc                  0.6.0                    py27_0
odo                       0.5.0                    py27_1
olefile                   0.44                     py27_0
openpyxl                  2.4.7                    py27_0
openssl                   1.0.2l                        0
packaging                 16.8                     py27_0
pandas                    0.20.1              np112py27_0
pandocfilters             1.4.1                    py27_0
pango                     1.40.3                        1
partd                     0.3.8                    py27_0
path.py                   10.3.1                   py27_0
pathlib2                  2.2.1                    py27_0
patsy                     0.4.1                    py27_0
pbr                       1.10.0                   py27_0    anaconda
pcre                      8.39                          1
pep8                      1.7.0                    py27_0
pexpect                   4.2.1                    py27_0
pickleshare               0.7.4                    py27_0
pillow                    4.1.1                    py27_0
pip                       9.0.1                    py27_1
pixman                    0.34.0                        0
ply                       3.10                     py27_0
pp                        1.6.4                    py27_0    geneko
prompt_toolkit            1.0.14                   py27_0
protobuf                  3.2.0                    py27_0    anaconda
psutil                    5.2.2                    py27_0
ptyprocess                0.5.1                    py27_0
py                        1.4.33                   py27_0
pycairo                   1.10.0                   py27_0
pycosat                   0.6.2                    py27_0
pycparser                 2.17                     py27_0
pycrypto                  2.6.1                    py27_6
pycurl                    7.43.0                   py27_2
pydicom                   0.9.9                     <pip>
pydicom                   0.9.9                    py27_0    conda-forge
pyflakes                  1.5.0                    py27_0
pygments                  2.2.0                    py27_0
pylint                    1.6.4                    py27_1
pyodbc                    4.0.16                   py27_0
pyopenssl                 17.0.0                   py27_0
pyparsing                 2.1.4                    py27_0
pyqt                      5.6.0                    py27_2
pytables                  3.3.0               np112py27_0
pytest                    3.0.7                    py27_0
python                    2.7.13                        0
python-dateutil           2.6.0                    py27_0
pytorch                   0.1.12               py27_2cu80  [cuda80]  soumith
pytz                      2017.2                   py27_0
pywavelets                0.5.2               np112py27_0
pyyaml                    3.12                     py27_0
pyzmq                     16.0.2                   py27_0
qt                        5.6.2                         4
qtawesome                 0.4.4                    py27_0
qtconsole                 4.3.0                    py27_0
qtpy                      1.2.1                    py27_0
readline                  6.2                           2
requests                  2.14.2                   py27_0
rope                      0.9.4                    py27_1
ruamel_yaml               0.11.14                  py27_1
scandir                   1.5                      py27_0
scikit-image              0.13.0              np112py27_0
scikit-learn              0.18.1              np112py27_1
scipy                     0.19.0              np112py27_0
seaborn                   0.7.1                    py27_0
setuptools                27.2.0                   py27_0
simplegeneric             0.8.1                    py27_1
singledispatch            3.4.0.3                  py27_0
sip                       4.18                     py27_0
six                       1.10.0                   py27_0
snowballstemmer           1.2.1                    py27_0
sortedcollections         0.5.3                    py27_0
sortedcontainers          1.5.7                    py27_0
sphinx                    1.5.6                    py27_0
spyder                    3.1.4                    py27_0
sqlalchemy                1.1.9                    py27_0
sqlite                    3.13.0                        0
ssl_match_hostname        3.4.0.2                  py27_1
statsmodels               0.8.0               np112py27_0
subprocess32              3.2.7                    py27_0
sympy                     1.0                      py27_0
tblib                     1.3.2                    py27_0
tensorflow                1.1.0               np112py27_0    anaconda
terminado                 0.6                      py27_0
testpath                  0.3                      py27_0
tk                        8.5.18                        0
toolz                     0.8.2                    py27_0
torchvision               0.1.8                    py27_2    soumith
tornado                   4.5.1                    py27_0
traitlets                 4.3.2                    py27_0
unicodecsv                0.14.1                   py27_0
unixodbc                  2.3.4                         0
wcwidth                   0.1.7                    py27_0
werkzeug                  0.12.2                   py27_0
wheel                     0.29.0                   py27_0
widgetsnbextension        2.0.0                    py27_0
wrapt                     1.10.10                  py27_0
xlrd                      1.0.0                    py27_0
xlsxwriter                0.9.6                    py27_0
xlwt                      1.2.0                    py27_0
xz                        5.2.2                         1
yaml                      0.1.6                         0
zeromq                    4.1.5                         0
zict                      0.1.2                    py27_0
zlib                      1.2.8                         3
