Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
can't install pyqt
Becker__Neal
I don't see how to install pyqt into intelpython environment:
conda install pyqt --channel=intel
Using Anaconda Cloud api site https://api.anaconda.org
Fetching package metadata: ..........
Solving package specifications: ....
The following specifications were found to be in conflict:
  - bzip2 (target=bzip2-1.0.6-intel_py3.5_1.tar.bz2)
  - db (target=db-4.7.25-intel_py3.5_1.tar.bz2)
  - icc_rt (target=icc_rt-15.0.6-intel_py3.5_1.tar.bz2)
  - libffi (target=libffi-3.2.1-intel_py3.5_1.tar.bz2)
  - openssl (target=openssl-1.0.2g-intel_py3.5_1.tar.bz2)
  - pip (target=pip-7.1.2-intel_py3.5_1.tar.bz2) -> python 3.5*
  - pip (target=pip-7.1.2-intel_py3.5_1.tar.bz2) -> setuptools
  - pyqt -> python 3.5*
  - python 3.5*
  - setuptools (target=setuptools-18.2-intel_py3.5_1.tar.bz2) -> python 3.5*
  - sqlite (target=sqlite-3.8.11.1-intel_py3.5_1.tar.bz2)
  - tcl (target=tcl-8.6.4-intel_py3.5_1.tar.bz2)
  - tix (target=tix-8.4.3-intel_py3.5_1.tar.bz2)
  - tk (target=tk-8.6.4-intel_py3.5_1.tar.bz2)
  - xz (target=xz-5.2.1-intel_py3.5_1.tar.bz2)
  - zlib (target=zlib-1.2.8-intel_py3.5_1.tar.bz2)
Use "conda info <package>" to see the dependencies for each package.
(intelpython3)[nbecker@nbecker2 envs]$ conda install pyqt --channel=intel --override-channel
Error:  Package missing in current linux-64 channels:
  - pyqt
Did you mean one of these?
    pytz
You can search for this package on anaconda.org with
    anaconda search -t conda pyqt
Robert_C_Intel
A workaround is to:
conda remove freetype2
You will switch some packages from intel to continuum, including matplotlib, but you will still have intel numpy/scipy
We are working with continuum to resolve depedences that make it difficult to mix packages.
Becker__Neal
OK, I did
Then:
conda install pyqt
  - python 3.5*
Robert_C_Intel
The problem is a version conflict between the packages we provide and the requirements of pyqt from anaconda. If you start from miniconda and create an intel python environment:
 conda create -n idp3m intelpython3_core
Then I am able to install pyqt with no conflict. If I start with Intel python installer, then there is a conflict on the versions of libpng, but uninstalling freetype2 removes the conflict and installs pyqt. I think you have a different combination of packages and the conflict is different. If you can tell me how to create an conda environment that shows the problem, then I can reproduce and track it down.
We have asked Continuum to update their package to also accept libpng 1.6.18, instead of only 1.6.17, which would fix the problem that I see. We are also looking at more general solutions to avoid version conflicts in the future.
Becker__Neal
The original problem was that when I tried to plot with matplotlib, I got no screen output (and now error message).
I did notice that
%matplotlib
said setting output to Agg.
Usually, I would see
In [32]: %matplotlib
Using matplotlib backend: Qt5Agg
So I thought maybe the problem was caused by pyqt not being installed.
Otherwise, my original problem is still that matplotlib doesn't seem to produce any screen output.
Robert_C_Intel
If you download intel python from intel and activate the root environment, it works. If you create a conda environment, with intelpython3_core and matplotlib then plotting does not work--it silently exits for me.
I think there is a missing dependence that is only uncovered when you install packages individually. I need to investigate some more.
