Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
curses missing on python 3.7
degommea
I was trying to run a script using ncurses on a conda installed intel python 3.7.7, and I kept receiving error messages :
import curses
ModuleNotFoundError: No module named '_curses'
I installed libncurses-dev, conda curses package without any luck.
After digging, it looks like all 3.7.* packages distributed on https://anaconda.org/intel/python (at least) are lacking _curses.cpython-37m-x86_64-linux-gnu.so (and _curses_panel.cpython-37m-x86_64-linux-gnu.so .. and maybe more, but I was only looking for curses), which should be in folder /lib/python3.7/lib-dynload/ in the package and provided by default by the distribution.
3.6.3 used to provide it ( _curses.cpython-36m-x86_64-linux-gnu.so in /lib/python3.6/lib-dynload/ ).
I checked on https://anaconda.org/conda-forge/python and they provide it with 3.7 and 3.8 python flavors, so it looks like it should still be provided as well on Intel's one.
I can confirm that manually stealing the file from conda-forge version has "import curses" working normally, but this is not sustainable in our worklfow.
Adweidh_Intel
Hi Degommea.
Thanks for reaching out to us. We are forwarding this case to SME, will get back to you at the earliest.
Adweidh.
Louie_T_Intel
Hi Degommea.
We escalated this issue back to engineer team.
If engineer team confirms the issue, the proper fix may come into later release of intel distribution for python.
Louie_T_Intel
Hi
We couldn't put curse into our release due to GPL license issue.
However, Update 2020.4 and 2021.1-beta10 will ship with pyeditline, and 2020.4 or beta10 will be shipped in weeks.
Hope pyeditline work for you.
regards
