Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
how to invoke ILP64?
kgore4
Can anyone tell me how to switch MKL to ILP64 on linux?  I've set MKL_LP64_ILP64=ilp64 in the environment before starting python
I'm getting errors which googling hints at using ILP64 instead of LP64 may solve the issue. The python line is amat=bmat+scalar*(amat-bmat) where the dimensions are 46717 square.
Intel MKL ERROR: Parameter 1 was incorrect on entry to vsSub.
Intel MKL ERROR: Parameter 1 was incorrect on entry to vsLinearFrac.
Intel MKL ERROR: Parameter 1 was incorrect on entry to vsAdd.
2.7.13 |Intel Corporation| (default, Apr 27 2017, 15:33:46)
[GCC 4.8.2 20140120 (Red Hat 4.8.2-15)]
Oleksandr_P_Intel
Thank you. We have reproduced the issue, and are working towards a resolution. We will update this post to notify you of a fix.
The choice between LP64 and ILP64 is made at the time of compilation, so setting the variable in the environment will not make a difference for Python.
Thank you,
Oleksandr
